Hello All,
Im looking to buy a Mini-Eco, like the Tenshock / Minicat racing USA ones, or something similar. Are there any available?
Hello All,
I've got a yellow Tenshock mini-Eco I could part with, it's not perfect but it is in good shape. I'll take some pics and post shortly...
I had a red one I wish I still had.
Lone-Wolf,
What motor does it come with?
Do you have any some props?
Are the problems just cosmetic?
Everything is stock on this one, motor, esc and prop etc...all you need to add to it is a receiver. I have not run it in years, I think you would just need to spend a few minutes and lube things up but other than that it's good to go. Grabbing camera now so expect pic's in a few minutes...
OK, pic's attached to this and a few more messages as the forum allows. As you can see the esc installed is a 60amp unit, I would also include the stock esc pictured in the last pic, nothing wrong with it but I now remember having trouble trying to program it so I gave up and just put this 60 amp unit in, it should work just fine if you have the patience to figure it out. Anyways, pictures are a correct portrayal, it's in better shape that I remember, all I can see is the prop needs sharpening and I would grease up the driveshaft. Let me know what you think and hope you like it.
Lone-Wolf,
Looks good!
How much do you want for it?
Well you make an offer!...I'm terrible at negotiating, should I have said that? ;-)
Ill give ya $150 for it.
Is there any markings on the prop of which one it is?
3200 KV Brushless motor?
OK sold and I can get shipping super cheap as the box will be small, will arrive through USPS with tracking. I'll PM my Paypal info in a few minutes.
I believe it is 3200Kv and not sure exactly what prop other than it's what came with it. Calipers show 28mm diameter and there is no way you'll get anything larger diameter-wise on there as this prop is a hair width away from touching the hull V.
Arrived safely. Thanks!!!
Awesome!! I hope you enjoy it, actually I know you will, that little hull is truly amazing what it can do...why did I sell it!! haha
When you get it going let me know what you think.
