Bill here is a new one for ya.
http://www.sinusleistungssteller.de/sls602.html
You can power your next 72" mono with it.
Steven Vaccaro
I have seen those, aren't they something crazy?!?!
60 volts will kill ya at 200 amps!
Steven Vaccaro
This brings up a good point. Higher voltage means higher amperage and thus higher voltage has more potential to kill. It takes only 100mA to stop your heart. A standard 9V battery can kill you.
A sailor took a Simpson 260 volt meter probe in each hand to measure his bodily resistance from thumb to thumb, but the probes had sharp tips, and in his excitement he pressed his thumbs hard enough against the probes to break the skin. Once the salty conducting fluid known as blood was available, the current from the multimeter travelled right across the sailor's heart, disrupting the electrical regulation of his heartbeat. He died before he could record his Ohms.
This has been calculated to produce 90 milliamperes to the heart.
Be Careful!
ReddyWatts fleet photo
I think i'll think twice about licking a 9V battery to see if it's still good now...
Yep...no more licking 9v...do it all the time.
I did get a big jolt when I was younger...came in wet after swimming at the lake house and had to reset the hot water heater at my dads...reached around there and zap...threw me 6 feet across and I hit the fridge. Burnt both fingers...in and out. My father in-law said you were lucky it was not 110v and that it was 220...for some reason less amps or something. All I know is I am pretty sure I wet myself.
Yes, I was stupid like that....it was just a buttom to hit but guess I made a connection.
That's why I only use one hand (helps to prevent the current from passing over the heart).
I also negotiated with my wife when we got married and bought a non-conductive wedding band (titanium) so I don't cut my fingers off! LOL.
ReadyWatts, you hit it right on the head. I've heard of this many times. Be warned of ANY current passing over the heart. If it tingles, you're already well on your way
Steven Vaccaro
