Page 2 of 6 FirstFirst 1234 ... LastLast
Results 31 to 60 of 170
Thread: Differences between high end ESC's and cheap ones for Lehner motors?
  1. #31
    Sep 2007
    NC
    2,783
    Depending on what the ESC will be used for and how tight the packaging is I will use something between 3500-6000uF. I replace all the four stock capacitors with 25V, 35V or 50V Rubycon ZL, ZLH or ZLK caps. If space allows I will add two more for a total of 6 caps.
    I prefer to use wire from GS Racing, Deans or the German supplier who's name I am forgetting.
    Progressive RC also has some good silicone wire.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
  2. #32
    Mar 2011
    BC
    7,629
    German supplier: Gundert?
  3. #33
    Mar 2015
    CA
    1,262
    nah it was something else. they're exclusively like some industrial Wire shop out of germany with a site that looks older than gundert
    ZL rubycon caps are like trying to find a unicorn... so I went with similar rated united chemicon caps. hopefully they'll last
  4. #34
    Mar 2015
    CA
    1,262
    The store's name is Nessel
    Their new store... which I could imagine is better than before:
    http://nessel-elektronik.net/
    Old store:
    http://www.nessel-elektronik.de/Sili...likonlitze.htm
    But i think they only ship in bulk, or charge high shipping... as usual. Tried ordering some time ago.
  5. #35
    Sep 2007
    NC
    2,783
    Nessel was the company I was missing the name. I have asked friends in Germany in the past to buy the wire for me and I pick it up when I am in Europe.
    The Rubycon caps are available from the major electronics supply houses like Allied and Mouser. OSE has some of them in stock.
    Tyler Garrard
  6. #36
    Mar 2015
    CA
    1,262
    Doubt anything from Nessel is anything like this stuff tho:
    https://tqwire.com/product-category/...ucts/11-gauge/
    TQ11 is constructed from 2,303 strands of bare copper in a super thin silicone jacket. The wire is only 4.2mm OD – providing a larger conductor in a compact space. Thinner than your “average” 12 gauge wire, it has more copper, allowing for increased current flow and lower voltage loss.
    New TQ 10 Gauge wire (version 2) is constructed from 1,050 strands of tinned copper to be very flexible, easy to solder and only 4.8mm in diameter. Available in Black, Red, Blue, Yellow & Orange and in several convenient wiring kits.
  7. #37
    Mar 2015
    CA
    1,262
    I now get a little nervous whenever I go on newark.com and at checkout they say this: "Exact shipping fees are unknown until the order has been processed."
    Because last time I ordered caps from them - they charged me $30+ bucks for shipping even though their estimate tools show $5-10 bucks max
    Great way to fleece customers. Unless they only caiter to businesses and it's expected?
    Digikey on other hand was super cheap for a much bigger order
  8. #38
    Feb 2008
    GB
    2,728
    I don't get it, what is the advantage to tin plated wires? Tin has near 7 times the resistance of copper, so surely it must increase the wire's resistance over normal copper wire.
  9. #39
    May 2017
    OK
    1,464
    Tinning keeps the wire from oxidizing. Oxidized copper is worse than tin. The best wire is silver plated copper, but not cheap!
  10. #40
    Feb 2008
    GB
    2,728
    Thanks Craig, that explains why the wire exists. I still wonder if it is of any advantage to me though, my boats spend at most an hour a month on the water and even then are unlikely to get wet, the only times I have seen green wires are when boats have been stuck in the bottom for extended periods of time, and then generally what the wire is attached to is only fit for the bin anyway.
  11. #41
    Mar 2015
    CA
    1,262
    I guess its a good idea to put enough foam so that it doesn't end up stuck on the bottom of the lake :)
  12. #42
    May 2017
    OK
    1,464
    Paul, you can seal the wires with PVC heatshring tubing and silicone. It’s not just the water environment that can cause the copper to corrode. As the wire heats, then cools, air is drawn in and out. The air carries water and over time, copper will corrode. This is the problem with car wiring. It’s normally just copper wire, no plating. After some years, lights aren’t bright and electrical systems don’t act right. Now that takes years, but we are running 100-200A thru the wire, so the process is accelerated. I seal all my wiring as mentioned above. An extra step to make sure the amps flow freely!
  13. #43
    Mar 2015
    CA
    1,262
    Have any of you ever replaced the stock conductor wires on the Castle ice before ?
    Thinking to make double conductor wires but the wires are so close to the fets I feel like any extra heat might damage them
  14. #44
    Feb 2008
    GB
    2,728
    I think most people run flotation, but if you hit the lake bottom sometime the lake monster will grab you, and if it doesn't want to let go no amount of flotation will help, sometimes it will pop up a week, month or year later, sometimes it is gone for good.
    Maybe it is a cultural thing, most of us in the UK pull about 45A average and the only times I have felt warm wires is when I have used a LiPo to jump-start my, or a neighbour's car.
    I have soldered the wires on an Ice 200, I took off the stock 8g wires to replace them with 10g which was more suited to my purposes for that ESC.
    The battery wires were just about doable, but the motor wires are the only thing my trusty Weller80 has failed to solder (within reasonable time, it could probably have done it eventually, but would have had to put an unacceptable amount of heat into the board, risking damage), the combination of the 8g wire and thick copper tracks in the PCB surrounding the wires wickd the heat out of the tip really fast, I had to cut the wires down to stubs to desolder them in what I considered to be a safe time.
    If you want to add another 8g wire you will need either an old style iron with a huge thermal mass, or a whole ship ton of power.
  15. #45
    Sep 2007
    NC
    2,783
    I have replaced the wires on mine and have to use the 200W cheisel tip iron. You have to be careful to not leave the iron on for too long or it will hurt the other SMD components. If you use a low watt iron it will suck the heat to the other end of the board and by the time you heat the joint up enough to remove you have probably reflowed the closest FETs.
    Tyler Garrard
  16. #46
    Mar 2015
    CA
    1,262
    aren't the bus tracks the wires are soldered to made from brass?
    anyway, i guess it'd be pointless to try to solder the 2 conductor wires to 1-2 inches of the original 8 gauge if i was to cut them off instead of soldering them off completely... since solder doesn't pass current well? was thinking to maybe connect the strand into each other rand then wrap thin copper wire around it
  17. #47
    Mar 2015
    CA
    1,262
    jeez Look what I found on my LMT 1950 :/ green oxidization on at least 1 of them and the rest look like they're just about to get just as bad
    They were all heatshrinked - is this because of flux residue? it hasn't touched water
  18. #48
    May 2017
    OK
    1,464
    Need to put silicone sealant under the heat shrink... heating and cooling cycles pulls water in from the air.
  19. #49
    Mar 2015
    CA
    1,262
    But would the flux residue contribute or make it worse though? I think I forgot to clean it after soldering
    btw, What kind of silicone sealant would be best to use for something like this.... something like this? https://www.amazon.com/Clear-Electro.../dp/B0063U2RT8
  20. #50
    ON
    2,912
    Quote Originally Posted by dmitry100 View Post
    This would never happen with tined wire.
    Larry
  21. #51
    Jan 2013
    Ga
    1,358
    Try some marine heat shrink
  22. #52
    Mar 2015
    CA
    1,262
    Tyler, any idea where I can get props similar to abc's? it appears even propshop has closed down
    Or can octura props be modified to 19* or 23* rake?
  23. #53
    Nov 2012
    De
    356
    Prop shop are still in business but under a different name Protean Design, you can find them on Facebook.
  24. #54
    Mar 2015
    CA
    1,262
    Tyler, is it worth replacing the 2x 1200uf caps near the power leads from my Castle edge 200 with 3 smaller ZL caps? Was thinking to keep it and just use an additional 5-6k ZL cap bank
    They also have 2x 560uf caps on the opposite end. It's best to have all of them match the cap bank? kind of figured the front ones wouldn't matter that much
  25. #55
    Sep 2007
    NC
    2,783
    I think the stock caps are 680uF on the battery wire side and 560uF on the center of the board.
    I believe it is worth replacing at minimum all four caps with the appropriate Rubycon ZL caps even if it's just the same rating. For the 8S ICE and EDGE ESC's I would recommend bumping the cap voltage up to 50V if you plan on running them on 8S. If you only plan on 6S and below use the 35V rated caps.
    If you are pushing the current limits, I add two additional caps for a total of 6.
    You can mix and match brands, but it's best to use all the same voltage.
    Tyler Garrard
  26. #56
    ON
    9,401
    Thanks Tyler.
  27. #57
    Mar 2015
    CA
    1,262
    It seems they changed the newest Edge 200 8s to 2 caps of 1200uf 35v on battery side. Probably better off with 2 of the 470uf ZL in their place. Thought 3 could fit but seems not.
    I could put 2 more on top of them but I figured having long cap leads would defeat the purpose.
    For pushing current limits ... is it a good idea to add an additional 5k cap bank on top of the 4 already on board? or are these Castle controllers designed well enough that they don't need that much
  28. #58
    Sep 2007
    NC
    2,783
    Castles need good caps, not necessarily a ton of them as long as they are on the board. Using external cap banks reduces the effectiveness considerably compared to the equal amount on board.
    Tyler Garrard
  29. #59
    Mar 2015
    CA
    1,262
    Btw, I read somewhere about spark resistors can cause problems with castle esc's... Potentially even damage them in some way. Something about it messing with the auto lipo detection. But that seems like something from a long time ago.
    I have a bunch of 11k ohm resistors on hand. Think they can still cause issues with the ice/edge 200 8s?
  30. #60
    May 2017
    OK
    1,464
    That is way too high! That can definitely cause voltage detection issues, on any ESC. Should be 10-20 Ohm range, 1/2W. Put heat shrink on the resistor. Keep a finger on it when pre-charging. If it gets hots, you got a short or other problem. Should be a very small spark, showing caps are still lively...
