Page 3 of 3 FirstFirst 123
Results 61 to 66 of 66
Thread: 37" TFL Genesis single motor SAW build
  1. #61
    Jul 2016
    199
    I was lucky enough to be there today to see this beautiful boat screaming across the lake Great job Ryan!
  2. #62
    Jul 2016
    4,119
    Thanks boys. I'm going to try and pull the log data off the ESC tonight and see what kind of RPM and Amp readings I got.
  3. #63
    May 2021
    NY
    67
    wow impressive, you put a ton of work into that hull.
  4. #64
    Jul 2016
    4,119
    Quote Originally Posted by naveda_08 View Post
    Thanks. Yes, it was a lot of work, but I learned a lot during the process.
  5. #65
    Jun 2021
    Ba
    8
    What glue did u use ?
  6. #66
    Jul 2016
    4,119
    Quote Originally Posted by CraigGenesis View Post
    This was one of my first builds. At the time I was using JB Weld for things like motor and servo mounts. I used 30min epoxy and chopped carbon fiber in the tips and for the deck stringers. Now I use mostly West Marine G-Flex epoxy thickened with silica powder
