Page 1 of 2 12 LastLast
Results 1 to 30 of 44
Thread: New 2004 Miss Budweiser T-6 Build
    Aug 2017
    Wa
    57
    Default New 2004 Miss Budweiser T-6 Build
    Basic :Spec’s
    1/8 Scale Hull is by RCBc All Carbon Fiber SG121-H running as 2004 Miss Budweiser T-6
    ESC: Alien Power Syst. 300 Amp on 8s 29.6 VDC
    Motor: NEU 1527 /1.5 /8mm on 8s & Water Jacket
    Motor Mount by HRC Mfg. 1527 floor mount
    Motor Coupler by MBP 8mm to ¼
    Battery’s: 2ea Nano Tech 6000 Mah in Series for 8S 29.6 VDC
    All the running gear is From Acuu-Tech
    Authentic Scale Strut , Turn Fin , Rudder Bracket & Tapered single pick-up Rudder
    Prop's By ABC # H-2215 -19' rake -38BAR & #H-2315-17' rake-45 BAR 2 blade Cleavers, thinned, sharpened & balanced. by Me
    First Day of the build removed all the release agent ( pain in the BUTT) established the boats Center line, and mounted the rudder bracket and rear wing vertical stabilizer bracket
    MORE TO FOLLOW Next mount Turn Fin ,Strut ,stuffing box & motor[B][/B
    7,629
    Nice, I have a sport hydro build coming up soon myself. Subscribed
    Feb 2010
    1,025
    Nice$$$
    ~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
    ****2008/9 MMEU LSO, 2008 LSH CHAMP****
    ~~~~~~~70 MPH Club Member!~~~~~~~~~
    Aug 2017
    Wa
    57
    Back to it the installed the turn fin, cut the hole and installed the strut. Roughly set the location for the Motor, battery’s and ESC to get a idea ware the C/G balance point will be .
    With battery’s located in the wells for fuel tanks in a nitro boat and the ESC placed in the bow’s forward radio box. The balance point is 3/4 TO 1 inch behind the rear of the sponson, which is close to the Newton Marines drawings c/g’s location
    Note : When U move the rudder to the left side of the hull the holes in the rudder pivot block are upside down.
    Instead of modifying the rudder. I took a chance and ordered the rudder pivot block for a Speed Master Turn Fin Bracket (they make both right & left hand pivot block’s) which by the way are identical to the Accu-Tech pivot block’s and fit perfectly .
    PROBLEM SOLVED :
    Motor mount holes drilled an motor installed. .
    Time to layout the locate and cut the hole for the stuffing box I always HATE this process TO EASY TO SCREW IT UP
    May 2017
    OK
    1,464
    CG sounds perfect! Is this going to be 1/8 scale build?
    Aug 2017
    Wa
    57
    Yes 1/8 Scale
    7,629
    Have you established a finished weight yet Tom? I’m just curious for my build, I have a 2028 and a 1527 and still contemplating which to use. The Castle motor is waaaay heavier
    May 2015
    tx
    245
    Perfect exactly what I’m looking for
    Aug 2017
    Wa
    57
    Screen Shot 2017-12-19 at 12.02.47 PM.jpg My 1/8 Nitro boat RCBC SG118-H 1994 Miss Bud T-3 hull weights 18 lbs RTR with Fuel
    I'll probably get torched for mentioning a nitro boat on a FE site LOL
    I think the FE boat might be a little heaver cause the Battery's & ESC weight more then the engine and exhaust system
    7,629
    Quote Originally Posted by Tom G View Post
    Oh man I’m shooting for 16lbs on my Edge Hydro. Or at least that is what I think I can pull off. I should be good with a 1527 or 1530 then.
    Ga
    5,266
    LOL I think you'll be fine.
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    Aug 2017
    Wa
    57
    What scale Hydro are U building 1/10 1/12
    good luck Hope U make 16 lbs
    My bare hull is 6.5 lbs As it sits in pic with the motor & the of majority hardware is 7 lb 11 oz plus the battery's ESC 6 .7 lbs = 13.7 lbs not including the rest of the other peripherals ,cowls, wings and the rest of the electronics, paint ect:
    Aug 2017
    Wa
    57
    The stuffing box hole has been cut & the tube fiber glass clothed & epoxy-ed into place
    As soon as the epoxy cures I'll grind off the excess e-pucky off and cut the tube to length
    More to follow
    Aug 2017
    Wa
    57
    The stuffing box install and shaft alignment are done with mock up. I sure like the HRC Mfg motor mount made the prop shaft shaft alignment a snap.
    If I hadn't screwed up the only piece of 5/16 tubing I have for the flex shaft while trying to arc it to align with the strut the drive line would've been finished .
    Next try I'LL use the ole trick of packing it full of ultra fine sand and heat it slightly with a heat gun so it will no kink agn.
    HOPEFULLY
    If anyone has a Simpler way to bend the tubing I'm open to suggestions
    May 2009
    AB
    483
    Steve has that covered :)
    https://www.offshoreelectrics.com/bend-brass-tubing.php
    Namba District 16
    Nov 2008
    Ql
    3,169
    I find the simplest way, without heat or salt or sand etc, is to roll a couple of layers of masking tape around the 1/4" flex shaft to make it a slightly better fit into the tube. The tape only needs to be a bit longer than the bend you want to make.
    Then insert it into the tube & form the bend with your thumbs & fingers, a little bit at a time while moving your pressure point backwards & forwards along the length of the curve that you want.
    It works much like the bending springs we use at work to bend PVC conduits.
    There are also any number of places that sell external bending springs for small tubes.
    http://www.ebay.com/bhp/spring-tube-bender
    Aug 2017
    Wa
    57
    Thanks for the input
    I had already had annealed the tube. BUT I had a brain Fart a local guy here reminded me to leave the flex in the tube
    Aug 2017
    Wa
    57
    Quote Originally Posted by 785boats View Post
    I had already had annealed the tube. BUT I had a brain Fart a local guy here reminded me to leave the flex shaft in the tube and slide some heat shrink tube over the flex shaft to help take up the extra space in the tube .
    Nov 2008
    Ql
    3,169
    Cool.
    I like the heat shrink idea. Sounds easier than rolling the masking tape around the flex.
    I'll give that a go next time.
    Aug 2017
    Wa
    57
    Cool.
    Plus there is no chance of the tape getting stuck in the Tube. If the heat shrink stays in the tube for some weird reason just take a heat gun and blow hot air down the tube it will shrink the heat shrink tubing and it will fall right out of the brass tube
    Aug 2017
    Wa
    57
    A little more forward progress for the mock up. Add some CF reinforcement to the high stress areas of the rear wing vertical stabilizers.
    Fab-d up the attachment point's for the upper rear wing stabilizer rods.
    A little more tweaking to get all the angles right ,install some flotation foam & then epoxy the vertical stabilizer half's together and move on too the rear wing and front canard
    Nov 2008
    Ql
    3,169
    Hi Tom.
    Looking good.
    Could you give a few more details on how the fin braces are attached into the fins please. The photos you have posted won't enlarge when I click on them for some reason.
    Where did you get the bits & pieces for the rods & attachments? I need to make up something for my U-3 Turbinator.
    Also, in relation to your CoG. Have you measured it with everything in place including the fins & wing & cowling.
    I ask this because your batteries seem to be so far back behind the sponson transoms in your earlier posts.
    I need to get my batteries right up into the nose pod to get the CoG within an inch of the transoms. And the motor as far forward as practical. Again, that's allowing for everything else in place along the rear of the boat.
    Cheers.
    Paul.
    Dec 2011
    437
    That boat in the photo looks really familiar.
    Aug 2017
    Wa
    57
    The bracket is a piece of .065 x 1/4 x 1 1/2 stainless flat stock bent 90deg.s available from Octura for air plane rudder support hardware and held in place with epoxy on the inside an 2 ea 2-56 screws & nuts and washers . Available @ Micro Fasteners
    RC Boat Co sells the rest of the the hardware bracket and rods ect http://rcboatcompany.com/AluminumParts.html
    The CG is close to what was mention as pictured all the hardware -motor installed and cowling just sitting on the boat. And balancing on a 1/4 dia rod across the width of the boat, 1 inch behind the sponson transoms. My 300 A ESC is quit heave @ 1 lbs .
    With the battery's in the nose forward radio box location it's was quit nose heavy.
    Hope that answers all Ur ??
    Nov 2008
    Ql
    3,169
    Thanks for the info Tom.
    I can easily fashion something up like that from all the Bits'n'Pieces I have lying around. Just needed the visual to kick my old brain into gear.
    The rest of the brackets I can also make.
    Unfortunately the cost & the exchange rate & the postage to Australia, makes them far too expensive to buy. The Egg pod & ram wings cost me a small fortune & the rear wing & fins were out of the question. That's why I'm making my own.
    I'll just have to deal with the weight penalty
    I guess the wooden boats are a lot heavier aft of the sponsons than a glass boat. Plus the fact that I am making the fins & wing from ply, makes them a lot heavier too.
    I'll keep playing around with the weight distribution. A lifting prop & some negative angle on the strut will help of course.
    Thanks again for your help.
    Cheers.
    Paul.
    Aug 2017
    Wa
    57
    Fab of the rear wing vertical stabilizer’s and setting of there camber angles done.
    Time to move on to assembling the rear wing and designing a method so adjusting its caster so is not a total pain in the butt.
    I learned a lot on the Nitro boat and the Definitely not going to do the same design on this FE Hull
    Aug 2017
    Wa
    57
    The CF material I ordered for the rear wing end plates will not be here till Tues. (5 days to travel 500 miles come on USPS Priority Mail a Chihuahua could make the trip faster )
    Since the replacement stuffing box tubing showed up Friday back to that project. So as to keep the build progressing forward. Racing season is stately approaching.
    Installing some heat shrink tubing on the flex shaft to take up the gap between the flex shaft and the tubing, worked like a charm the S bent needed coming out of the thru hull tube and into the strut went off with no issues NO DENTS ,NO DINGS & NO KINKS and the flex shaft an heat shrink tubing all slide out of the brass tube LIKE BUTTER.
    ITS HELL TO GET OLD AND FORGET ALL THE LITTLE TRICKS U USED 20 years ago LMAO
    Aug 2017
    Wa
    57
    Front Ram wings ,Rear wing and Canard mock-up completed.
    Made a design change from the nitro boats installation
    Instead or a just a¼ inch elongated slot in the trim brackets.
    I’ve added 3 brass inserts in the sponson & vertical stabilizer side plates in addition to the 1/4 elongated slot in the trim brackets to increase the available amount of canard and rear wing adjustment. ( unused holes will be filled with 4-40 stainless set screws when not in use)
    Now on to mocking up the Cowl , exhaust shroud ,and turbine tray
    Dec 2015
    La
    550
    Looking good.
    Aug 2017
    Wa
    57
    Installed the 2 under deck cooling water and discharge lines.
    Mocking up and fitted the Cowl & Cowl latches, exhaust shroud, and turbine tray close to being done. I just need to clean up and round off of some corners.
    Paint the Driver and Cockpit then I can install the cockpit floor pan and windshield in the cowling.
    Then it’s on to the much hated body & fender work and paint.
