Results 1 to 12 of 12
Thread: Jacking plate
    Jan 2013
    Va
    150
    Default Jacking plate
    Does anyone know of a outboard motor jacking plate for rc boats? If not I am thinking of milling a few out to try on a project. Is there any interest? I was hoping a few were already made commercially but I can’t find any
    Mar 2017
    or
    236
    prather makes one for gas but they are too large for most the FE outboards
    Jan 2013
    Va
    150
    Thank you I will check it out
    Jan 2013
    Va
    150
    Could you happen to provide a link I can’t find it
    Ga
    5,267
    There is a gentleman (Captain Vic) on International Waters that used to sell them, not sure of his current status.
    http://www.intlwaters.com/index.php?showuser=1067
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    Mar 2017
    or
    236
    sorry cant remember where I bought the prather jackplate but here is a knockoff sold as "Prather Style JackPlate"
    Mar 2017
    or
    236
    here is are some nice setback mounting brackets OSE sells, the mount holes are slotted for some adjustment on the transom, but it would be much nicer if it had an adjustable jackplate & take it a step farther than I modified my OSE setback mounts "add built in tilt/trim" while your on the engineering project..... I have a design in mind Im just not capable of producing it. if your interested
    maybe the guys building F1 hydros would be interested in something like this, I know I would like a one piece setback with adjustable jackplate and trim all in one unit for my next build
    I made an adjustable jackplate to mount on these OSE setback brackets (made this video for another post)
    Jan 2017
    Ma
    170
    What type of hull are you going to mount the jack plate an outboard too? On my OPC tunnel boats I like the Prather mounts available thru K&B mfg. in both 3.5cc an 7.5cc sizes 30$ or so. I also use K&B lowers on my tunnels, so they were made for each other, not sure what other lower O/B unit would fit the Prather mount? Du-Bro also makes adjustable mounts for O/B's also for K&B an O/S lowers not sure it is compatible with any other O/B lowers? I guess it all depends on what O/B and what hull you are using it on, commercial ones may not be available, you may have no choice but to fab up your own design.
    Jan 2013
    Va
    150
    I am going to run two ose mini o/b on a nitro converted to electric blackjack 26
    Jan 2017
    Ma
    170
    I've seen a few of those BJ26's on flee-bay, thought they would make a cool O/B conversion. What's the transom height on that hull, spoonson bottom to top transom? Larger 3.5cc size O/B's need 3" transom height, those mini's and the H2O style only need 2" transom height. Probably going to need a one inch spacer / mount for front of O/B motor to hull clearance.
    On
    7,279
    Quote Originally Posted by Mph621 View Post
    Those were a very tippy hull..not sure adding outboards would be a good idea.
    Jan 2013
    Va
    150
    I had them on it already ran pretty well just need to be able to adjust the depth
