Results 1 to 6 of 6
Thread: Thread size
    Jul 2017
    VI
    93
    Default Thread size
    Does anyone know the thread size of this shaft?
    ProBoat Heavy Duty Flex Cable SW36, TC31.
    Jul 2017
    VI
    93
    Oct 2014
    1,500
    This is the prop nut suggested.
    https://www.offshoreelectrics.com/pr...d=mc-94205A230
    Says "These work well as a propeller nut on 4mm threaded .7 pitch shafts"
    Have fun with that....
    Jul 2017
    VI
    93
    I was thinking about cutting the straight end of the one i have shorter and I would have to cut a new thread into it afterwards so i was hoping to know if the thread size was the same as the cutter i found which is 10 - 24
    May 2009
    AB
    483
    I think it would be a 4mm die cutter. But you might not have to cut it, can you use a piece of fuel tubing between the nut and the prop to take up the extra room?
    Namba District 16
    Jul 2017
    VI
    93
    Hmmm. Thats an idea that never crossed my mind. Thank you very much for the suggestion I think I will do that instead of cutting my shaft.
