Results 1 to 20 of 20
Thread: Need help finding a very small esc
    Oct 2013
    la
    8,740
    Default Need help finding a very small esc
    I’m looking for a small esc. I’m currently using a castle talon 35. I need something close to those dimensions and at least 25a. I do not want to use a pistix anymore and it has to be at least up to 4s. It needs to have a built in bec also. So to sum it up
    Size (around) 23mm wide x 49mm long. Height don’t matter
    Built in bec
    No pistix needed
    25+ amps
    At least up to 4s
    Maybe my talon can used without a pistix, if it can I’m not sure what I need to do. Any help would be appreciated. Go. Lol
    Jan 2013
    Ga
    1,358
    What radio are you using? Spektrum I used an air ESC with the sub-trim throttle turned all the way back
    Oct 2013
    la
    8,740
    Quote Originally Posted by dmitry100 View Post
    Why not YEP 300? 150amp double stack... with pistix of course.
    Not sure if I should even reply, but are you being serious? I said a bery small esc. It’s going in something about the size of the esc your talking about. I need a micro esc.
    Oct 2013
    la
    8,740
    Quote Originally Posted by jim82 View Post
    I’m using a spektrum. That’s all I need to do is turn the sub trim back? Will I still get 100% throttle?
    Sep 2007
    No
    59
    EnErG Pro Marine 60 Sbec Esc is a pretty small esc
    Mar 2011
    BC
    7,629
    I’ve got a couple around Travis, I’ll go look now
    Mar 2011
    BC
    7,629
    I have three but one is a brushed ESC one has no BEC and the third is a Traxxas Velineon 3m, not sure of amps on those
    Oct 2013
    la
    8,740
    I don’t think the traxxas one will do 4s?
    AZ
    8,010
    Spektrums work great with all Castle air ESCs. Just use the right settings, no PiStix required. Haven’t used the latter in many years.
    WA
    8,335
    Make sure you set the Castle ESC for "Fixed Endpoints".
    Darin E. Jordan - Renton, WA
    Jul 2016
    4,119
    what's pistix?
    Oct 2013
    la
    8,740
    what's pistix?
    It’s a small device that allows you to use an air controller with a ground transmitter.
    Thanks guys. I got it to work. So I just chopped a couple grams off and saved myself $25 for each time I need to use this.
    Oct 2013
    la
    8,740
    Does anyone have a small talon esc they would part with? I wanna see if a 25a will hold up or even the 15a talon.
    Jul 2016
    4,119
    There's a couple used 25A and 15A talons on eBay. This one has a best offer tag on it: https://www.ebay.com/itm/Castle-Crea...4AAOSwEzFZ47v6
    Mar 2015
    CA
    1,262
    kfxguy, unrelated but ... do you have a link to that one nice mini pump you got a while ago? Can't seem to find it in the forum
  16. #16
    Oct 2013
    la
    8,740
    Which one? I still have them all. Pm me if you want one because I’m not using them.
  17. #17
    Jun 2015
    Wi
    734
    You could try one of these. I’ve ordered a few gforce motors and other things from here and theyve held up.
    http://www.valuehobby.com/power-syst...e-30a-esc.html
  18. #18
    Mar 2015
    CA
    1,262
    I would look at maybe using a 20-30amp Drone controller... there are some super small ones out there and firmware you can easily modify for your needs.
    They come in all shapes in sizes and there are insaneeeeeeeeeee varieties.
  19. #19
    Dec 2015
    La
    550
    What ca building? Just curious.
  20. #20
    ON
    9,401
    Turnigy plush work on wheel radio. Decent escs but need waterproofing. Should be the size you need with Bec.
    *Sorry, discontinued. Might grab a pair of the 100s since they modify easily for spec boats.
