Results 1 to 7 of 7
Thread: TFL Pursuit shaft upgrade
    Mar 2016
    LA
    47
    Default TFL Pursuit shaft upgrade
    I'm wanting to upgrade the shaft in my pursuit. The one I have has a strut instead of a stinger. Would anyone know which one piece shaft would replace the stock 2 piece?
    Mar 2015
    166
    OSE sells one for the stinger drive that you could just shorten for use with a strut.
    I'm not 100 percent sure but I believe the only difference is the flex shaft for the stinger version is slightly longer.
    OSE used to offer a flex shaft for the strut version but I don't see it being offered anymore.
    Mar 2016
    LA
    47
    That's the only solution I see. Everywhere I looked doesn't have it. They probably quit offering it so people would upgrade to a stinger or integrated drive.
    Mar 2015
    166
    Maybe PM Steve at OSE to ask if it's a viable solution?
    Let others know if it will work if you go this rout.
    Best of luck.
    Mar 2016
    LA
    47
    I see the upgraded carbon fiber pursuit has the strut. I don't see an upgraded flex anywhere.
    Mar 2016
    LA
    47
    Here's the one piece flex for the strut: ose-HD-cable-pursuit-21strut
    Mar 2015
    166
    Good to see you finally found one...happy Pursuiting
