Results 1 to 7 of 7
Thread: Pacer 5 minute +15 minute epoxy ?
    Jan 2011
    497
    Default Pacer 5 minute +15 minute epoxy ?
    Hi all i noticed my 5 and 15 minute epoxy resin has start to crystalize i heard some one mention you can heat it up with a heat gun or put the resin bottle in hot water to thin it out. My ? here is by doing that with if affect the epoxy's bonding ability and long term strength ? Regards Andris Golts ?
    3,117
    Nope... I have done this in the past with no ill affects on the epoxy.
    Apr 2017
    QL
    1,038
    Yes use by date is up.
    9,402
    I tried some 10 year old 30 minute epoxy the other day and it worked fine.
    Apr 2017
    QL
    1,038
    normally the Hardener crystalizes i have noticed with old z-poxy resins.
    3,117
    De-crystalize it with heat. ie... hot water, microwave, hairdryer
    Then mix up a test batch and make sure it cures. If it's stored properly and it still cures in the correct time; I wouldn't worry too much about dates.
    Later
    Mike
    Jan 2011
    497
    Thanks to all for the information. Regards Andris Golts
