Results 1 to 29 of 29
Thread: Creating a steerable drive
    7,629
    Default Creating a steerable drive
    Hey guys, I’ve always liked the steerable drive unit idea, making it work successfully is another matter. I have a twin pair on a 40” mono and the problem there is that when turning right the drives lay over that way and the right prop digs further into the water as the boats leans over. This creates lift and spins the boat out if you are not careful. Sooo, I got to browsing one day and going thru some parts and realized that MTC drives are a good place to start a new creation. https://www.modellbaucenterlorenz.de....html?___SID=U
    These drives have a ball socket where the drive tube meets the mount allowing for full adjustment and swing of up to 30* each way. It is also a good seal to keep water out.
    I removed the adjusting arm and got a turnbuckle to take its place( have a ton of car gear around) with ball links
    My plan here is to get this drive to act as a pendulum where as it moves left or right it raises to follow the hulls V.
    7,629
    So as it sits in the above pic the drive moves back and forth on a even plane. Not what I’m after. I tried a longer turnbuckle but the same result. It took some thought but I started thinking about camber and such(once again from the car memory banks) and thought what if I moved the pivot point of the turnbuckle forward or rearward it would change the geometry. So I made this rough cut piece of aluminum:
    And now I have 5mm lift at 15* throw.
    Well that’s where I am at right now. Ingenious suggestions on improvements or theory shall be appreciated.
    Jun 2017
    PA
    30
    Interesting idea.
    Do be aware though that if you change the drive angle of the drive it will also have an effect on how much vertical movement you get in the arc of your throw. You would have to shim the upper pivot in/out to compensate.
    Also you may be better off turning your top mounting point 90* for added stability and articulation.
    4,116
    Sean, thought of your project when I saw a picture of this setup recently on a scale Fountain
    7,629
    I have seen that one Ryan and Werner at WD200 has some as well http://www.wd200-modellbau.de/?Antri...kbarer_Antrieb
    Quote Originally Posted by RaisedByWolves View Post
    Interesting idea.
    I haven’t found the articulation to change at this point. The drive angle would not change much(unless I ran ABC props, lol). I am thinking the same on rotating the top pivot 90* and possibly pin it top and bottom instead of a heim joint. I need to figure it how to stabilize the stinger from rotating. I did mount one side hydraulic arm but the rotation issue is present.
    7,629
    And I think the answer is in the picture that Ryan posted. The way that the center arm attaches to the drive should stabilize it. Thank you buddy.
    Many years ago, steerable outdrives were very popular on RTR boats. The power available with round cells was much less than what we have today, but we discovered that as we increased the speeds of the RTRs with better motors and more cells the boats gained a strong tendency to hook and spin out in the turns. This happened with all of the different outdrives boats the club members ran. Up to a point they performed well, then hook city. It will be interesting to see if the OP’s boat can overcome this tendency.
    7,629
    Haha, I had a Graupner Portifino that ran great for its time, then a Systems 7 catamaran from Graupner. Both with steerable drives. Hoping I can sort this out somehow. I just like the Arneson look.
    Thanks Jay.
    4,116
    Glad it helped. Figured a picture of a known working setup, albeit HUGE, might offer a shortcut.
    7,629
    So lets see if I can get the pics straight if I go thru my laptop
    So i think I have the geometry right. I do need to rework the bracketry into something presentable. But I have 3/8" lift/swing and this should fair well on the 43" Magnum hull it will go on. Not sure if the fin laying over with it will help or not but it looks good to me.
    I am thinking of have a chat with my favourite CNC machinist to see if we can make duplicates.
    4,116
    Is the aluminum block off the transom just a spacer at this point to get the geometry right?
    The swing looks perfect!
    7,629
    Yes but there is lots of meat there that I can mill down into something presentable. Something triangular I’m thinking now. Perhaps 3 mount bolts at transom? Mmm
    Jun 2017
    PA
    30
    Looks good.
    Cant see the canted fin being a problem as it will be vertical when the boat is leaned into the turn.
    4,116
    I had assumed you'd triangulate the mount for strength eventually and that this was a mechanical proof of concept. Regardless of the final design, you're going to need a transom mounted GoPro to catch is in action!
    7,629
    Agreed, I like the cut of your job sir! Lol
    Jul 2009
    5,669
    Sean, How did this come along since Feb?
    I'm getting ready to remove the steerable Werner drive from my 58 Fountain because I cannot for the life of me get it to run correctly. the drive is large for the boat and Werner was kind enough to mill the housing to fit the back of the Fountain, but Ive tried over and over rebuilding, getting COG as far back as possible etc and I just cannot get it and am giving up on the project and rebuilding it.. HOWEVER, I saw this and if I can get a more correct scale drive on the boat, maybe, just maybe I can get this thing running.
    Overall the main issue I'm having is it is running very wet. My COG is spot on with others who run the same hull and Ive rebuilt the boat 3 times to get weight as absolutely far back as possible and it still rides wet. The hull has been blue printed, there is no hook in it that would cause the nose to be forced down. What I think it is, is the prop is way too far behind the transom. Its an incredibly long drive for a 58" boat.... But, those MTC might just work if you figured it out.... Or if I need to get one and continue to figure it out. But, great idea. if you didn't get it, I'm on board to get his thing working.
    Let me know. Hope your doing well.
    Oh, and pics can be found at Scottskiracing.com
    7,629
    Hey Scott, glad to hear from you. This is a gasser? I have been in alotta talks with Andy(AC Boats) and a lot of the gas boats are simply built to run wet and stick to the water. Racing is a bit more prolific in gas and it is (as you are fully aware) best if the boat stays in the water, AND gas doesn’t care much what it takes to push a wet boat. My Lazer 40” twin is much like this.
    You may be on the right thought on shortening the distance between prop and transom. This should help the prop ‘lift’ the hull out of the water.
    7,629
    I should have the milling/large machine back setup soon here to continue on my single drive idea.
    BUT.... this all started with my twin Lazer with steerable outdrives. It does tend to spin out when in a corner as the prop dogs into the water deeper when the boat leans over in the corner.
    You can see it occur in this vid: https://youtu.be/pDkBbDtpdEM
    Sooo, this is what I came up with over the weekend:
    Testing this next weekend.
    Feb 2018
    PA
    330
    I really like it...
    7,629
    Quote Originally Posted by 30nitro View Post
    I really like it...
    Let’s hope it works as designed
    Jul 2017
    34
    Very cool
    7,629
    Well in my opinion it worked fabulous. I can still spin it out but only on hard throttle.
    BTW, this runs on 8s with TP 4030’s at 1180 KV. After this run batteries were close to perfect storage charge of 60%,
    Feb 2018
    PA
    330
    Ok.........I want one......
    Jul 2017
    34
    So perfect ....nice job !!!
    7,629
    An AC Lazer twin? Or the steerable outdrive thang?
    Apr 2018
    OZ
    276
    Sweet bro
    7,629
    Quote Originally Posted by Rcsurfrider View Post
    Quote Originally Posted by Speedfreek View Post
    Sweet bro :thuumbup1:
    I’ll get it out onto the other lake today or tomorrow. It’s a lot more open and private. But I’m happy and can’t wait to get back to the single version.
    Feb 2018
    PA
    330
    Steerable out drive....
    7,629
    As promised, I got it out on open water
