Results 1 to 5 of 5
Thread: a question about prop longevity.
    Mar 2017
    ME
    86
    Default a question about prop longevity.
    Baring hitting something or otherwise damaging the prop does a sharpened and balanced prop wear out and if so what is the usual life span for a Beryllium Copper propeller.
    Aug 2010
    uk
    2,887
    You generally hit some thing & damage a prop long before you would wear one out, the sharper & thinner the blades will get nicks in the leading edge easier. This will require re dressing now & again, unless the damage is more severe.
    Mar 2017
    ME
    86
    Thanks. That's kind of what I thought but I was curious so I had to ask.
    Aug 2010
    uk
    2,887
    Cnc alloy props damage the easiest ( very easy to damage ) then beryllium copper with stainless steel being pretty tough.
    9,400
    Matter in the water is always dulling your props.
