There are many ways to get there, but for the moderate speeds the OP wants I’d recommend that motor with a Kv between 1000 and 1250. These will allow you to run larger more efficient props in the 50-52 mm range while keeping the amp draw low and run time longer. You don’t need 35,000 rpm to run mid-40s. The SK180 will be enough ESC for this setup, and that motor mount will work with the right cooling jacket length.
Just for reference, I currently run a 1100 Kv motor in my 34” SprintCat on 6S through a Raider150 ESC. With an Octura x455 speed is in the upper 40s and average amp draw is around 90 amps. With an x457/3 speeds are low/mid-50s with an amp draw closer to 115. It’s a great sport setup with lots of flexibility.
Reason: D*** Autocorrect!
