Page 1 of 3 123 LastLast
Results 1 to 30 of 78
Thread: U-31 MILLER HIGH LIFE 8th Scale build thread
    Feb 2010
    MI
    1,025
    Default U-31 MILLER HIGH LIFE 8th Scale build thread
    Gents, I'm making a lot of progress on my winter project U-31 `Miller High Life' Unlimited Hydroplane. Based on the Lucero designed Circus Circus platform, the`Miller High Life' was campaigned briefly on the 1988 Unlimited circuit. The scaled down 43" hull will legally meet all overall dimensional info provided on the NAMBA MHR#8700.
    I inherited this project from a good friend as a plywood framed skeleton from Newton #146 plans. Most of the wood frames were disguarded after being used for patterns in favor of stronger G10 Epoxy sheet composite. CF angle will also be used for structural support, plywood Transom & Sponson bulkheads are G10 skinned. West Systems #610 2-part epoxy is used for bonding and Z-Poxy for sealing a bonding any wood to wood component. The center section of the hull has been offset from Port to Starboard for FE clockwise racing. Epoxy Glass Canopy, Cockpit and rear Wing Set(on order) are RC Boat Company pieces.
    Power will be provided by IMPBA legal 1527 1.5y or Plettenberg HP370 BM A1-S on 10s1p lipo. Offset 3/16" cable driveline and hardware will consist of a combination of Zipp Kit(turnfin) and Speed Master(rudder,strut) components. Same hardware and driveline setup is used on my U-1 Atlas Van Lines.
    Here's some pics so far showing rear afterplane tub construction. Everything is swiss-cheesed to save weight. Working my way forward to start soon on front sponson & canard spar structure.
    ~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
    ****2008/9 MMEU LSO, 2008 LSH CHAMP****
    ~~~~~~~70 MPH Club Member!~~~~~~~~~
    Feb 2010
    MI
    1,025
    Default Cockpit/Canopy
    RC Boat Company canopy to be integrated into the hull.
    Apr 2016
    mt
    275
    Ken,
    Nice job. Makes me itch like crazy just thinking about cutting all that G-10. Great idea though.
    Bob
    Sep 2017
    MI
    409
    Great build! That is very cool! Can't wait to see it finished!
    Mar 2011
    BC
    7,629
    Very nice. The canopy will really set it off.
    Feb 2010
    MI
    1,025
    Default Picklefork Structure
    Worked on locking down the front sponson structure. The (2) CF angles are tied together with hardwood beams bonded to inside sponson walls to eliminate pickle fork twist. The forward CF angle will be part of the nose canard wing structure while the rearward CF angle will support the sponson transoms tying them in to the tub.
    Sponson bulkheads and stringers next...
    May 2014
    mi
    643
    I bought these decals back in the 80s
    and never used them.
    just realized these are for the Miller American
    not the Miller High Life.
    Feb 2010
    MI
    1,025
    Default Sponson structure
    Bonding the Sponson transom & bulkheads along with stringers
    Ga
    5,266
    Looking good Ken!
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    Feb 2010
    MI
    1,025
    Thanks for the nice comments guys. This nasty Mi. winter is providing me with lots of shop time.
    Hopefully if all goes well i'll have some better competition for you Doug!
    Nov 2008
    Ql
    3,169
    Coming along very nicely.
    I've never seen a hdro built up out of G10 epoxy sheet before.
    Very interesting.
    Feb 2010
    MI
    1,025
    Quote Originally Posted by 785boats View Post
    Very interesting.
    Thanks I've been following your U-3 build also your doing a great job! I've built plywood kits too, just to hard to repair when bad things happen.
    Feb 2010
    MI
    1,025
    Working on the sponson bottom structures today. The West Systems 610 2-part epoxy i use on the G-10 takes overnight to dry so I try to setup something up for bonding as frequently as possible.
    Feb 2010
    MI
    1,025
    CF angle air trap vents are in!
    Feb 2010
    MI
    1,025
    Bonding sponson bottom stringers, note right pic show CF flat plane ride pad forms
  16. #16
    Feb 2010
    MI
    1,025
    Bonding the after-plane non trip top form stringers
  17. #17
    Jun 2009
    MI
    2,536
    Ken, This is awesome!! When you mentioned G10 the other day, I wasn't envisioning this much of it! Nice!
  18. #18
    Feb 2010
    MI
    1,025
    Thanks Pete lots more G10 to come
  19. #19
    MI
    3,112
    Hi Ken,
    Looking good! Do you have a bare hull weight target your working towards?
  20. #20
    Feb 2010
    MI
    1,025
    I'd like to keep the hull under 5lbs, I know its going to be tough.
    The deck, bottom and ride pads skins will be G10
    Vertical sponson and after-plane non-trip surfaces will be Styrene sheet to keep weight down.
  21. #21
    Feb 2010
    MI
    1,025
    Bonding the engine cowling support opening structure.
    Heavy swiss-cheesed hardwood Airfoil blocks are bonded in. These really strengthen the whole front canopy/sponson structure to the afterplane.
    Canopy nose construction up next...
  22. #22
    Feb 2010
    MI
    1,025
    Laying out deck skin patterns
  23. #23
    Jun 2009
    MI
    2,536
    She's lookin good!
  24. #24
    Feb 2010
    MI
    1,025
    Lower Canopy nose and sidewalls are bonded in! Future home for 10S1P 5000-6000 lipo.
  25. #25
    Aug 2017
    Wa
    57
    Quote Originally Posted by K.R.Joye View Post
    Do-in some nice wrk there
  26. #26
    Feb 2010
    MI
    1,025
    Default Canopy attached!
    Added a CF bonding strip to the nose side wall before attaching the Canopy fuselage. There's a removable rear top canopy piece for battery compartment access.
  27. #27
    Feb 2010
    MI
    1,025
    Default Wing assembly!
    RC Boat Company Wing Assembly and upright mounting. All 3 wing parts have packing foam sheet cores for floatation. Upright bases have G10 slide in sheaths bonded in. Blue masking tape is used throughout the build to keep exterior surfaces clear of excess glue
  28. #28
    Feb 2010
    MI
    1,025
    Wing attachment hardware and mounting. Wing position is set neutral parallel to the rear after-plane bottom surface. Also showing removable canopy battery access panel bonding.
  29. #29
    Feb 2010
    MI
    1,025
    Zipp Kit (large hydro) 7075 Turn Fin modified and mounted. Speedmaster 21 Rudder w/transom load transfer gussets installed. 6-32 SS Allen Bolts used throughout w/blind nuts sealed w/epoxy.
  30. #30
    Feb 2010
    MI
    1,025
    Hydro Strut `G10 Wet Box' fabricated with a hardwood base is bonded, fastened to the hull bottom and transom. This is a long strut setup on offset driveline, angle-depth adjustment bolt will offer ease of access at deck surface. Faux`Turbine Exhaust' tube will hide any strut hardware proud of the deck.
