New guy, long time modeler here.
Looking to set this hull up with twin EP1 outboards for FE/Scale performance. I understand the limitations of the bottom end gears in these motors so im not looking for all out speed. I will be modifying the motors for much improved lower end lubrication as I have done in the past on similar outboards like the old school Robbe Roqua.
I have found this thread where a member here has done similar and would like to duplicate his success but there were some variables he left out of his thread.
https://forums.offshoreelectrics.com...-console-build
On page 5 of that thread he gives details on the motors and props used but I cant find direct current replacements for what he used. He lists 240KV Feigao motors and two Venom 32mm 1.4 counter rotating 3 blade props.
I also need to figure out how high to mount the motors on the hull for a good starting point.
I plan on power trim via a 3rd channel and linear servo with a custom made tilt bracket. I thought about also making a jack plate but figured it would be over kill for this.
Any ideas you guys could give me as to direct relacement motors and props used in the linked thread or motor mounting tips would be greatly appreciated.
