Looks like your just about there now Jim, i like the Savox servos too.
Have you guys played around with the cog? If so where is best? I'm currently messing around with everything trying to get that sweet spot. So far 62mph on 4s
what motor are you running with the 4s set up Jim ? also what type of prop ? I have my 4s pack approx 4 inches in from the transom and the hull seems to ride quite nice. c.o.g. is set around the 60/40 or balanced at the trailing edge of stock turn fin.
Did you add weight to the front? I am putting lipo as far forward as I can and cog is near 2in. behind the turn fin. I am running 1515 1y prop is 1450mod prop b/s. I need to work on my H-7 and try it.
woops, sorry Jim the cog is just about the same as you have . i was thinking of my jae 21/fe balance point not the jae-33.
i know these jae,s due to the ski like to be abit tail heavy and don,t like a lifting prop. how does your ride ?
Rides good just need some days of no wind to get it right. It has been crazy windy here lately
Hows the size of the 12 next to the 33. same length as a 33 sponson.
That is the mini. I been thinking about building a 12 though
Tried out the H-7 today 65.4mph
so the H7 is faster than the 1450. is the H7 stock ?
Stock h7. Going to try this idea out I'm sure someone has tried it before.IMG_20180328_123911546.jpg
just make sure there are some spring locking washers behind the wing nuts Jim. not sure if i like that idea though.
Yea once I get everything set right I will probably use regular self locking nuts. Just helps right now to make adjustments faster
The TP motor that originally had in there was squealing so I had to order some new bearings hopefully that will fix it
Jim, where you have your turn fin set now [ in pic ] is that about the position of the rear where its going to be left at , or are you still going to try different angles ? the setting now looks like your trying to keep the sponsons wetter , has your hull been riding abit loose in the front ?
That is when I just put the new bolts on about right here is where I have been setting it.IMG_20180328_192955563.jpg
I found with my 4s set up the fin needed to be raised approx 1/8 th inch at the trailing edge to stop speed flutter letting the sponsons ride a little wetter for choppy race conditions but for any calm water non race the fin was set with the top parallel to the top of sponson as in your last pic. overall c.o.g. balance seems to be quite good as the hull sits up nicely and handles very good at speed.
does the boat track straight with no steering input?
Yes dead straight . i did set the right sponson to 3/16 inch tow - in.
Changed bearings in my Tp3650 2060kv got it back in the boat now on 4s. First run with H-7 64.6mph if the wind would chill out I have a couple more props to try.
I have a T.P. 3650 - 2350 kv motor i would like to try in my JAE-33. currently running a HET 650-2200 motor and it is going very well or should i say was going very well until the modded h7 prop dropped off thanks to a dull prop nut.
Ouch. Blue Loctite man
no i can,t rely on using locktite as it doesn,t set off quick enough when your changing over props. i will now use a new nut for every secound prop change as the nuts are dirt cheap to buy.
Got a chance to run again today using a 2015. I'm up to 68.7mph and pretty sure she still has more in her with that same prop
Jim, are you still running 4s power ? if so not sure if its the best idea to run lifting props on the jae unless the ski is removed , an octura x648 should get you over 70 mph in saw trim so i have been told. can,t complain about almost 69 mph though.
Still running 4s yes with the Tp3650 2060kv. That's not a lifting prop but I have used both and results the same. Now when using a ski you can turn a bigger prop easier
Same everything as last time made a slight turn fin adjustment. 69.6mph!
Starting to get up some good speeds now Jim even with that size motor is good. I would like to try my 3650 - 2350 kv motor in the jae33 to see how she goes but at the moment i have a Het 750-2250 kv motor on 4s going very well, even stays with the Neu powered jae,s in club.
Het makes good motors. I been thinking about getting one while I wait on a custom TP for the 12g I'm building
