Page 1 of 7 123 ... LastLast
Results 1 to 30 of 193
Thread: Common caps for two escs?
    Aug 2008
    CO
    7,080
    Default Common caps for two escs?
    Is there any reason to not do this:
    Twin set up, common battery bank... I'm thinking of putting the caps in the parallel harness, as opposed to dedicated set of caps for each esc after the split.
    Thoughts? I'm not imagining a problem, but would like to learn from somebody else's smoke if there is a reason to NOT.
    Jesse
    "Look good doin' it"
    See the fleet
    May 2017
    OK
    1,464
    The only thing that comes to mind and the reason I wouldn’t do it is because you are doubling the ripple frequency. These frequencies are not synchronized, so they will dead beat on each other and there will be periods where the ripple current will be double, which is pushing the caps too far. We are already pushing capacitors well into the danger zone on FE boats. I would use two different banks, but share a common ground. So in essence you would be making a 3-leaded capacitor Bank.
    Aug 2008
    CO
    7,080
    Hmmm, would you mind posting a schematic? The ripple factor is the part I was concerned about.
    I imagined the caps as shock absorbers damping out the ripple. But I can see how ripple from esc A could go also to esc B and get everybody cornfused.
    See the fleet
    May 2017
    OK
    1,464
    Yes, I’ll post a pdf showing how I would construct it. I use copper plates in my cap banks to keep resistance low and help to cancel the unwanted inductance in the conducting elements. I’m going to be building a dual motor hydro this year, and will use this exact method..
    May 2017
    OK
    1,464
    Could you share with me how much current you expect to run to EACH ESC? BTW, the battery will be split into a 3-leaded configuration to match the cap Bank. The drawing will show that...
    AZ
    8,010
    Caps should be as close as practical to the ESC, so use separate banks for each ESC. For high frequency ripple, more, smaller caps will work better than a few big ones. That said, I’ve had great success on SAW setups using three to five 1000 mF caps, each one bridging the two power wires rather than all of them on a pigtail.
    May 2017
    OK
    1,464
    Here's a PDF of the Cap Bank I would use. As Fluid mentions, it is extremely important to get it as close to the ESC as possible. Using a common ground, you can use on the BEC outputs from one of the ESC's to power the electronics. If doing that, be sure to isolate the second ESC's output by removing the middle wire on the signal in at the ESC. A capacitor I'm having great results with is this from Mouser Electronics:
    P/N 661-EGPD500E362MM40H, 3600uF, 50V Aluminum Electrolytic Capacitor. This capacitor has the highest ripple current rating and lowest ESR than any other cap I've found in this range. This is suitable up to 8S operation. FWI, caps with higher voltage rating always have lower ESR than a reduced voltage counterpart. Always apply a 20% de-rate to the voltage spec of a cap, never use it at the defined voltage rating! I hope this helps you...
    Attached Files Attached Files
    ON
    2,917
    I always wire my ESC's together, so each motor see's the 2P setup.
    Would I wire the caps the same as your pic or differently,
    Right now I have 3 on the board and 5 on a pig tail on each ESC. 6-S 2P (Turnigy 180 - V2's)
    Larry
    Sep 2011
    BA
    296
    Aug 2008
    CO
    7,080
    Thanks Craig, I think I'll do something similar, but bring the batteries in series. I'd like them to get drawn down together. This may require separating the cap banks completely. I'll post a picture when I get it wired.
    See the fleet
    May 2017
    OK
    1,464
    Sounds like you’ll be using a separate external BEC and isolate both BEC outputs from the ESC’s? You need to keep your ground potentials close between the two ESC’s, or you’ll form unwanted ground loops thru the control side. Sounds like you know what you want, I’m sure it will all work great!
    Aug 2008
    CO
    7,080
    Ground loops? Only one I know about is the one when my rocket with pontoons did when I was a kid.
    Yes external receiver pack, and all very short wires. I've pulled the red power wire out of both controllers.
    See the fleet
    May 2017
    OK
    1,464
    Hmmmm, confused Jesse, you’ve got 5,573 postings on an FE forum and this is the first time you’ve heard of ground loops? It’s only the #1 cause of erratic receiver behavior. I’m finding that hard to believe...
    Sep 2011
    BA
    296
    Excuse me,
    would the loop be a junction node between the ground terminals of both sets of ESCs / motor / battery?
    I understand that on my boat the ground wires that come out of the ESCs (RX) are the only ones that are attached. Also external BEC and both positive cables isolated in the esc. Use a "Y" harness where you eliminate the red wires.
    I saw the drawing in pdf ... magnificent !. And I understood that I am missing the ground connection in both systems.
    May 2017
    OK
    1,464
    A “ground loop” is not a purposeful wire. Rather, it is a unintended current flow thru some of the ground conductors. It is the biggest reason people experience gremlin like behavior in their boats. I’ll try and give an example. Suppose we wire the duel ESC’s as the OP suggests. It seems simple and straight forward. Wire each side independently, where one batt set feeds one Cap Bank and ESC and another similar pack feeds the other side. The grounds and hots are kept separated between the two systems. Now let’s assume this is running 4s on each side. Each ESC has a BEC output, but only one can be potentially used. The problem is WHICH battery is going to supply the power for the control electronics, either thru the BEC from one of the ESC’s or from an External BEC, fed from one of the batteries. The OP says no BEC, use a separate battery pack for the control electronics. That’s fine, but it doesn’t address the problem, which is the Y cable you mention.
    You see, no matter how you connect this configuration, that Y cable is going to try and short the two grounds together. The problem is that the grounds EACH have their own ripple voltage, and the peaks and valleys are out of phase, or asynchronous to each other. When the ground voltages don’t match, then that Y cable is going to try and short this ripple voltage difference and guess what, the control electronics are going to lose the battle. It causes a large current flow in the ground of the Y cable, which can easily disrupt any part or all parts of the control electronics.
    It is for that reason that my PDF shows the grounds of the two batteries closely tied to each other on the common ground plane of the Cap Bank. Now the ripple voltage will only appear different on the positive side of each battery. Now, you can tie the positives together too, and many do that so that they discharge evenly. But that desire comes at a cost. Tying the two positives will now force all caps to see the voltage/current ripple of BOTH ESC’s. They are out of phase to each other, but at times they will add up to huge values, and this is very hard on the caps. It’s just exactly like the manner huge rogue waves are developed at sea. Ocean waves as they get large, get asynchronous to each other. Every once in a while, two big waves add in height and you have a 100’ wave staring at you, from nowhere!
    Same thing happens in an electrical system. So I put up with the small amount of uneven discharge. I alternate the packs every other run. But my caps run cool, and I don’t have huge waves of electrical power to contend with. My apologies to the OP, I’m sure he would prefer to see this posted elsewhere.
  16. #16
    Sep 2011
    BA
    296
    Thank you for taking the time to detail the situation.
    Excuse me for interfering. I found it very interesting and useful.
  17. #17
    Sep 2011
    BA
    296
    Make a connection with a conductor between both earth connections of the esc or caps. Thank you very much.Inked25442832_1771890443112689_7268919452023559472_n_LI.jpg
  18. #18
    May 2017
    OK
    1,464
    Needs to be a conductor as big as the wire size going to the cap Bank. Just to let you know, round wires create external magnetic fields around them very easily. Those magnetic fields creates inductance, which is called “leakage inductance”, because it’s not directly coupled to a power source. This causes a loss and increases ripple current/voltage on the system. Flat copper plate does not create near as strong of an external field, so no leakage inductance. That reduces ripple... your wire helps, but you’ll still have quite a bit of ripple on that wire at currents over 120A.
  19. #19
    Aug 2008
    CO
    7,080
    Don't think that since I've been on this forum for ten years I know everything... or that I want people to think that...
    See the fleet
  20. #20
    May 2017
    OK
    1,464
    I didn’t imply that you thought you knew everything. I just thought that making that rocket crack and making light of an electrical problem that has probably caused people to suddenly run their boat into something hard was in bad form. Most you veterans could run circles around my knowledge on boat setups, racing tactics, prop configurations and many other topics. But I know electrical systems, and the bizarre behavior they can produce. I’m trying to help someone! I put effort into making a drawing that illustrates my point. It didn’t feel very good having that effort minimized.
  21. #21
    Sep 2011
    BA
    296
    Thank you very much sir!
    These topics are very interesting. They clarify many random defects that occur in electrical systems.
  22. #22
    Aug 2008
    CO
    7,080
    Craig, you will find that The OP has a dry sense of humor, but I have no intentions of belittling anybody or an opportunity to learn.
    My comment about the ground loop was a jab at nobody but myself referring to a very memorable failure. I never excelled in physics 2 electricity and magnetism. I'm a visual learner and without schematics I can't visualize the electromagnetic enigma. I honestly have never heard of your ground loop before.
    This is the perfect place for extended discourses and I welcome all opportunities to reduce my electromagnetic ignorance.
    So the y harness is the power, not the radio wires? Is this gremlin behavior like when you unplug one esc from the battery, hit the throttle and the unplugged motor turns a little?
    I calculate that I'm pulling 70-90 amps average in the application... so far. It will only go up with bigger props.
    The "ground" is the electrical sense not the physical. I'm getting there...
    I'll need to go back through the posts several more times as it is still not crystal clear.
    Thanks for putting up with me
    See the fleet
  23. #23
    Aug 2008
    CO
    7,080
    What do use for this? I'm assuming it's for the cap board.
    See the fleet
  24. #24
    Sep 2011
    BA
    296
    "Is this gremlin behavior like when you unplug one esc from the battery, hit the throttle and the unplugged motor turns a little? "
    I experienced that situation when I had placed the harness "Y" and had only removed the red wire that was attached to the RX. (the two red cables of the esc had been joined by the harnes "Y").
    Remove all positons / reds from the "Y" harness.
    Excuse my English, I try to understand.
  25. #25
    May 2017
    OK
    1,464
    Quote Originally Posted by Jesse J View Post
    I get my copper plate from online metals.com here’s a link: https://www.onlinemetals.com/merchan...966&top_cat=87
    This is 0.062” material, good for 150 A at 1/2” width strips. For higher current, I double the strip up, by soldering to one side then stack another plate on top, then solder the two together. I made a big cap Bank for Dasboata (Chris). You can get some details from him too. It has stacked plates. That was a 300A Cap Bank to get his surface car to 150mph.
  26. #26
    May 2017
    OK
    1,464
    Quote Originally Posted by golfito View Post
    No, that was probably the residual charge left on the ESC’s internal caps. This ground loop behavior really only shows itself while the vehicle is under load. It needs to be at high amp output, then the ripple problem and loops start to show up. For most of us, we’re just running our boats then suddenly it takes a weird turn or the motor cuts out or the ESC just burns for no apparent reason. The reason many ESC’s burn is because the ground loop current upsets the microprocessor and it glitches the program. This causes the ESC to lose lock on the rotation of the motor. If it sends pulses incorrectly timed, the resulting current overload will smoke the mosfets.
  27. #27
    Sep 2011
    BA
    296
    I'm going to implement it on my boat. I was able to get 10 AWG cable. It is my first construction and I am reviewing all the electronics before executing it.
  28. #28
    Aug 2008
    CO
    7,080
    Here is a vid from a while back.
    im still not completely there on the ground loop thing.
    In this video, the second motor is not plugged in to any battery. The receiver line is connected to a y harness, but the esc power leads are both unplugged.
    https://youtu.be/Qyq4xSFAnsM
    Thoughts?
    See the fleet
  29. #29
    May 2017
    OK
    1,464
    That’s cool! Just to re-cap:
    1) ESC 1 is plugged into a battery, while ESC 2 is not.
    Question: Do either ESC’s have a BEC?
    2) Both ESC’s are plugged into a Y Cable
    3) The Reciever is powered up, assuming this true since the motors are responding to a speed input.
    Question: Hard to see from vid, but does the unplugged motor rotate in the proper direction, i.e. opposite of the other motor.
    I think I know what’s happening, but need verification and question answered. Bottom line, you may be demonstrating the exact nature of the problem I was describing. Meaning wire connections can have unattended consequences! Thanks for sharing
  30. #30
    Jul 2016
    4,125
    Oh, I see what you did there. Clever.
