Results 1 to 7 of 7
Thread: Two Octura 1740 props - balanced + sharpened
    2,913
    Default Two Octura 1740 props - balanced + sharpened
    https://www.offshoreelectrics.com/pr...?prod=oct-1740
    ----Dia.----------------Pitch--------- Ratio--------Shaft
    mm ---Inch. -----mm----Inch.
    39.9--1.57------ 67.8----2.669 ------1.7--------3/16"
    2,913
    I guess nobody runs the small riggers any more.
    Jun 2013
    NV
    179
    I have a nitro outboard cat that I decided not to convert. No prop was included in the deal for it. So have no idea what to run. 42mm is the largest prop that will fit. Would this work? If so would be great! Then i would have no excuse to not get some fuel and a battery for the glow plug.
    41" & 29" FE Aeromarine Sprint Cats, Quickdraw powered "Dollar Eater" 41" Insane Cat, 29" BL mod Graupner Cat, 24" Hydro, 29" OB Cat, BL mod NQD Tear Into Jet boat, 55" Scarab, JET SWEEP R/C pool skimmer Rescue Boat.
    2,913
    Greg
    These are 40mm so they would fit.
    I know nothing about Nitro Cat's , so I do not know what the 1.7 pitch will do for you besides more speed.
    I do know that these props have some lift in them.
    They are yours if you want them.
    If so Send me a PM with your full shipping address.
    2,913
    Gifted to 78MaicoRider
    May 2017
    OK
    1,464
    Big difference in props between nitro and FE... not much info on nitro on this site, this is an FE forum.
    Jun 2013
    NV
    179
    Thank you!!! Yes I am aware of that. I have several FEs (inc a 70mph 29" sprintcat. and have a lot of respect for 100mph club members) a Quickdraw powered Insane Cat and this outboard nitro cat I was planning to convert to FE outboard if I ever get around to machining the parts on my mill. Then thought a prop, fuel, and batt to lite the plug. Might as well see what happens. I have no experience with nitro. If they don't work well on nitro power band, It will make me get on making some parts.
    Thank You so much!
