So how's the project going ? What direction you going? What prop, projected speeds? I think a 30" hull on 6s will be entertaining. I've been playing all summer with a little 24" Dumas HS Sprint, set up with a UL-1 motor on a K&B lower & Seaking 120 amp esc, fun boat. The un tested project boat is a AquaCraft VS-1 291/2" tunnel hull. I've got an OSE Raider 36x60 1700 kv on a OSE 80915-v2 lower, esc is a Seaking 120 amp, set to run on 6s 5000mah 50c. Not sure on prop choice, want to start conservative, see how it handles first, ride height thrust angle ? then go for speed prop.
