Originally Posted by
Hotrods
Anyone out there have any tricks up their sleeve to battle the torque roll on single motor mono? I have tried offset weight to the starboard side and small props. Any suggestions?
This a sport boat let that be clear---
44 step bottom mono
5692 1090kv
10-12S
SF240
been running X447 round ear
Well what’s the inside of the boat look like? Reason I ask is you may have it way off balance. If you do then that would cause issues. The prop you have shouldn’t be causing you issues unless it’s not sharp, from the looks of it, it looks pretty thick on the leading (cutting) edge. If that’s the case then that’s definitely an issue. It also appears that your shingle is mounted too low. If the prop is too deep in the water that will cause it to roll. You need to concentrate your main weight towards the center of the boat. On a mono I don’t like to counter weigh it to counter roll, lower center of gravity seems to work better in my experience.
Something else that will cause instability is if the rudder is too narrow or too short or it has slack or if the steeering rod isn’t thick or rigid enough to keep the rudder in control.
I’d also imagine if the motor is mounted more flat in the hull vs at an angle that may amplify torque roll.
Most of the time is just the prop is too deep and if you have a narrow hull then there’s a chance it sits lower in the water at speed because of its lesser width. Just my .02
Edit. I just looked at your pic again. My suspect is your rudder is at least 1” too short. It’s hella short. That will definitely cause it to roll. No doubt about that. I know you’ll lose a mph or two but you have to decide what’s more important. You can always pick it back up by optimizing things. You really need to move on from octura props and try some abc props, I’ve found that the equivalent similar prop in an abc vs octura, it’s about 8-10mph faster.
