My son has a 650EP cat hull with a single drive flexshaft. As delivered from the factory the strut is positioned with a negative attitude. No amount of upward adjustment will even align the bottom of the strut in a neutral alignment. The forward web on the strut actually contacts the hull with the strut still negative.
The stuffing tube exits the hull with a downward angle all the way to the strut whereas I feel the stuffing tube should exit the hull in a smooth curve then level out and enter the strut in a neutral (horizontal) alignment, thus allowing for either positive or negative adjustment of the strut as necessary. The stuffing tube has been incorrectly fitted so that the strut is mounted too high in the hull and yet still has a negative attitude with no possibility of raising the strut to correct it.
Thus the stuffing tube requires replacement with a new tube that exits the hull and enters the strut in a neutral alignment. To set up the stuffing tube I need to know a neutral position to set up the strut to get the right curvature from under the hull. That is, what is the orientation of the strut in relation to the adjacent sponson stepped surface, please to set up a neutral attitude for the strut?
