Make sure your batteries that you use for your trucks that you plan to use in the boat are good high c rated (something like 45c or above). You will need (2) 10MM wrenches, a set of metric Allen wrenches, Marine grease, hatch tape or electrical tape. I suggest the below items as immediate needs/upgrades.
https://www.offshoreelectrics.com/pr...ct-ocfhe5mm15d (you need this only if you get the .150 upgraded OSE shaft)
https://www.offshoreelectrics.com/pr...-bj29-v3-cable
https://www.offshoreelectrics.com/pr...rod=hatch-tape (black electrical tape will work if you get into a jam)
https://www.offshoreelectrics.com/pr...od=HH-dyne4200
https://www.offshoreelectrics.com/pr...rod=hh-dyn4401
