I am running the Leo 4092 1390kv motor in a 42" mono with a V2 T-180. While there has been a lack of on water time recently, I have raced it sucessfully against the gassers in our club and it holds it's own. Currently up to a Prather 240 and GPS speed of 88 kph, with the hull running stable. The hull looks to have seducer styling in the bottom with a ride pad, so it can be somewhat flighty and tend to bow steer. I deliberately used a speedmaster stinger as it is height adjustable, with a flood tube. Lifting the stinger right up has taken out the chine walk and allowed bigger prop use comfortably. A few more prop tests yet to go. I use this boat just for racing so perhaps a little out of what you are wanting to achieve, but the motor you are looking at works fine in a hull this size, and if you aim for speeds in the 70-75 kph range you should get reasonable runtimes (esp. on 2P) and a boat the runs and performs well.
I have to say that what seems to have gotten lost lately is the recommended rpms for sport running and racing. Around 24K for sport and 30K for racing in general works well in keeping things reliable. Serious racers learn where they can push the boundaries, but for fun play boats 35K is just asking for trouble, not to mention excessive wear and tear on the running gear, ecs's and hardware. The old KISS principle! I see so many guys with the mindset that more power must make them go faster, sometimes it does, but at a cost. Learning how to tune a boat and find the right prop will get much better gains with a lot less wasted money.
