Results 1 to 10 of 10
Thread: bad motor?
    Jun 2011
    ct
    826
    Default bad motor?
    had a problem again with my twin aeromarine 36" cat. seaking 180's leopard 4082 1600's. on 5s. last week a motor wire got hot. replaced loose bullet. ran today . boat ran fine. when finished run, all motor wires were hot on that same motor. connections were tight. what gives?
    May 2017
    OK
    1,464
    This seems to be related to the one side, so stuffing tube/flex cable running with more friction than the other, prop not as sharp on that side, ESC's aren't running with the identical timing. I would swap stuff, one piece at a time, to try and widdle down the variables. First thing I'd swap are the motors or ESC's...
    BTW, you can carefully bend the fingers of bullet connectors back out to fix loose fits. It's only when the gold plating is gone that I would chuck it.
    AZ
    8,010
    The above are likely causes. Was the motor hot or just the wiring? If it was just the wiring then poor connectors/soldering could be the cause. Was the hot motor the one on the inside or outside of the turns? If running an oval course the inside motor will run hotter.
    May 2017
    OK
    1,464
    Never knew that about the inside motor, but makes perfect sense. Like a locked out differential in a street drag car, the inside tire gets murdered... Does anybody know if there is a "mixer" available for dual motor setups? It's a little module you plug into both ESC's and the steering thru a Y connector. It performs a speed mix, based on the steering position, to slow down the inboard motor ratiometrically to the steering input. They use these types of devices on fighting bots... wouldn't that help dual motor boats turn better?
    Jul 2015
    701
    Use a 6 channel air radio with V tail mixing to independently control each esc. Twin motor tug boat guys run it like that. I haven't tried it on my tug yet, but I don't compete with it. I find it unusual for one motor to be hotter than the other simply due to making right turns. First I've heard of it actually.
    AZ
    8,010
    Been pretty well known for a long time - among oval twin racers. They run wide open in rather tight turns, you'd probably never notice it during zip-zip running.
    Mar 2013
    ny
    367
    It's because one prop is a bit deeper then the other in the turns
    May 2017
    OK
    1,464
    Quote Originally Posted by iop65 View Post
    Actually, I think it's because the inside prop is cutting a shorter path so it's fighting the speed setting of the motor. It's forcing that prop to run a more inefficiently.
    ON
    2,912
    Radio's such as the Futaba 4PV have mixing for dual ESC,s built in for this use.
    Larry
    Mar 2013
    ny
    367
    No,it is because one prop is deeper:more load it's as simpel as that
