Results 1 to 11 of 11
Thread: Ferrite ring
    Aug 2017
    OZ
    686
    Default Ferrite ring
    Upon reviewing several You-tube videos I noted that some had the wires from the receiver to the ESC wrapped several times around a ferrite annular ring. Is this to stop interference?
    Apr 2017
    QL
    1,038
    Yes.
    Aug 2017
    OZ
    686
    Many thanks
    May 2017
    OK
    1,464
    It forms an inductor and slows the edges of the ripple, especially important with a switch-node BEC. This ring should be located close to the receiver, not the ESC or BEC. I also add a small, electrolytic capacitor to the RCVR using an unused port. The combination of the inductor and capacitor makes a solid filter. The cap also really helps if you're using a high force servo or digital type. These can pull large amounts of current and glitch the RCVR.
    Aug 2017
    OZ
    686
    Many thanks. Would these be suitable please?
    http://www.ebay.com.au/itm/2-x-Power...QAAOSwwGdZz~OL
    These ones a receiver end fitting should fit through the inner diameter
    http://www.ebay.com.au/itm/10-x-Powe...wAAOSwg9dZz8ZE
    Apr 2017
    QL
    1,038
    JayCar Electronics and other Electronic stores have these rings also.
    Aug 2017
    OZ
    686
    Many thanks
    Oct 2013
    la
    8,740
    I usually remove the ferrite ring. Never noticed a difference. Except that it didn't get in the way with my wire routing anymore.
    Aug 2017
    OZ
    686
    Many thanks. My son just uses the glitch buster capacitor on the receiver.
    7,279
    Ditto...never an issue without them...just dead weight.
    Aug 2017
    OZ
    686
    Noted. Many thanks
