I wanted to know what kind I amp draws can you expect to see from a Q Hydro. I do understand I it will depend on prop selection weight boat running wet these kind of factures. The boat is a sport 40 whiplash motor Neu 1530 .75y prop tried aluminum 2 blade 4814 48mm batteries revolectrix 60c 4400 mah 2p rtr weight just under 12lbs. Had a turnigy 240 esc in it until it stopped working so I tried my 220amp swordfish with data logging and thought the amps would be lower then my 4s p hydro. What seem to lower the amps was running an older set of turnigy 4000mah 30c.
The boat needs more set up as it seems to hop a little https://youtu.be/l1gXqNqWVIE
