Results 1 to 4 of 4
Thread: GP 400 rudder offset and setback
    Sep 2013
    NJ
    151
    Default GP 400 rudder offset and setback
    Well, apparently the parts I have are not conducive to one another. I believe the rudder setback ad prop arc are not supposed to be aligned. Is tis te correct assumption? The only way to rectify is to put the strut in the boat a-la Atlas. It's coming along...
    Cool
    Plenty of hydros run the prop and rudder opposite one other - one advantage is the prop wash hits the rudder and helps to counteract prop walk. If you feel you just have to put the rudder behind the prop arc, then all you need is a longer spacer for the rudder. They are available with up to 4" of set back IIRC.
    Sep 2013
    NJ
    151
    Thanks for the info, fluid. I'll keep it where it is for now.
    Jan 2014
    Md
    323
    I use the same one you got on all my sport hydros over 4s. Works good for me.
