Page 4 of 5 FirstFirst ... 2345 LastLast
Results 91 to 120 of 150
Thread: HPR 5009c bulletproof build
  1. #91
    Sep 2017
    ZN
    86
    Thanks, that was my first thought. Now I know I'm on the right track.
  2. #92
    Sep 2017
    ZN
    86
    Quick question....
    Should the drives be level? I've attached a pic, please let me know if this looks correct.
    Thanks.
  3. #93
    Nov 2011
    SA
    1,837
    Brad, you should have the option to be level as its a good starting point for setting up the boat. You may find as you go faster there will likely be a need to put some negative angle into the drive.. It's looking really good! Take your time and it will pay off in the end.
  4. #94
    Sep 2017
    ZN
    86
    Thanks Kent.
  5. #95
    7,630
    Hey Brad, I was just doing some clean up and found the stock HPR motor mounts. You have yours?
    Drives look good BTW
  6. #96
    7,630
    I was using long straight edge pressed up against the inside of the sponson and took measurements at two points on the drive tube.
    and ditto. And if you want to take it a step further run tubes/shafts in places of the prop shafts to extend your reading out further. I think I used 6mm brass 12” long and a 3ft straight edge along sponsons.
    Hope I’m not too late on this one
  7. #97
    Sep 2017
    ZN
    86
    Thanks, got all the mounts from Kent.
  8. #98
    Aug 2016
    187
    Hey Brad, how's your build going? You still working on this?
  9. #99
    Sep 2017
    ZN
    86
    Hi Ryan
    I'm still working the build. Looking good so far, I've really taken my time getting the hull ready for paint. There were loads of tiny cracks in the gel coat and the one of the sponson tip was damaged in transit from Switzerland so I've had some repair work to do. Its a 100% now though.
    Living in South Africa has also made it a bit challenging to find little bits and pieces like washers and screws so I've had to import all that stuff, it took eight LONG weeks for my washers to arrive.
    I'll post a few more pics of my progress.
  10. #100
    7,630
    Nice to hear it’s coming along Brad. I hear you on the little bits, I ordered coloured washers from HK during Chinese New Year and I still don’t have them.
  11. #101
    Aug 2016
    187
    Yes, good to hear. I'm planning a hpr115 for my next project, so keeping an eye on how you guys do things
  12. #102
    Sep 2017
    ZN
    86
    Hi All,
    I have finally got the motor mounts and servo holder glued in and and like a true first time boat building novice decided to lay carbon fiber down to strengthen the mounts.
    ..that was indeed a character building experience. The end result seems to have worked out nicely though.
  13. #103
    Sep 2017
    ZN
    86
  14. #104
    Sep 2017
    ZN
    86
  15. #105
    4,119
    Coming along nice. Don't sell yourself short, the build looks really good. 3M Panel Bond is something I see used with great results on servo and motor mounts and the results are often very tidy and neat. I have not used it myself yet, but will on my next project.
  16. #106
    7,630
    Yup, looks good, nice and clean. Nice work Brad
  17. #107
    Sep 2017
    ZN
    86
    Thanks guys
  18. #108
    Sep 2017
    ZN
    86
    Hi Guys,
    Quick question, I read in this forum that guys use black silicon to mount their battery trays. Would this be advisable for my boat?
  19. #109
    4,119
    Yep! I use black aquarium silicone sealant, recommended to me by several builders. I wish you could mount everything inside the hull with that stuff because its so easy to keep neat and clean lines.
  20. #110
    Sep 2017
    ZN
    86
    Awesome, thanks Ryan.
  21. #111
    Sep 2017
    ZN
    86
    Hi guys,
    I'd like to order my servo today. How many KG's of torque does it need?
    Thanks.
  22. #112
    Nov 2011
    SA
    1,837
    Low profile around 10kg something like savox 1251 will do fine. But there are many servos you can use depending on wallet.
  23. #113
    Sep 2017
    ZN
    86
    Ok cool, thanks Kent.
  24. #114
    Sep 2017
    ZN
    86
    Hi All
    I'm sourcing some pipe for the through hull pickups. What should the inside diameter be?
  25. #115
    4,119
    The factory inlets installed on my HPR are made from tubing that measure 0.166" which is a little over 4mm on the inside diameter.
  26. #116
    Sep 2017
    ZN
    86
    Cool,
    Thanks Ryan
  27. #117
    Sep 2017
    ZN
    86
    Photo update..
    Servo and ESCs are in.
  28. #118
    4,119
    Looks awesome
  29. #119
    Sep 2017
    ZN
    86
    Thanks.
  30. #120
    Sep 2017
    ZN
    86
    Quick photo update...finished the water pickups today. Took forever to find 4mm pipe, eventually found some at a hydraulics machine shop.
Tags for this Thread
