Page 2 of 5 FirstFirst 1234 ... LastLast
Results 31 to 60 of 150
Thread: HPR 5009c bulletproof build
  1. #31
    Nov 2011
    SA
    1,837
    I make those parts by the way ��
  2. #32
    Sep 2017
    ZN
    86
    Awesome.. what a small world. I'm sure when everything arrives I'll have a few questions for you regarding the installation.
  3. #33
    Sep 2017
    ZN
    86
    Quote Originally Posted by Prodrvr View Post
    Ok, just found a vid of the boat and wow. This guy is running 105.5 mph on two TP 4050 2350Kv, two T180A esc's, two 6s 5000's, two X457 props cut down/modified.
    Hi John, I ordered a set of sharpened and balanced x447 octras and a set of x457 octras to cut down.
    From what I've read I need to cut them down to a 50mm. Do you have any experience with this?
  4. #34
    Jul 2015
    701
    Quote Originally Posted by Bradb74 View Post
    Sorry, I do not.
  5. #35
    Sep 2017
    ZN
    86
    Ok cool, I'll consult the Oracle and see what I can find.
  6. #36
    Jul 2016
    4,116
    Contact Chris Hoffmann, member Dasboata
  7. #37
    Sep 2017
    ZN
    86
    Will do, thanks
  8. #38
    Mar 2011
    BC
    7,629
    If you are to get some reduced 457’s done detounge them and remove some blade area. Make sure to tell Chris this oryou will draw unecesary amps
  9. #39
    Sep 2017
    ZN
    86
    Hi all
    My hull finally arrived today from Switzerland :-)
    I'll start the build in a week or two when I have a little time off.
  10. #40
    Jul 2016
    4,116
    Just got my C5009 hull and hardware in as well. I won't be starting my build for a while, so I'll be watching your progress for ideas.
  11. #41
    Sep 2017
    ZN
    86
    Cool, we can compare notes.
  12. #42
    Mar 2011
    BC
    7,629
    So are we all going to be comparing notes on running come spring? Haha
  13. #43
    Mar 2015
    CA
    1,262
    How are the new HPR hulls (the new guys who took over HPR) are they of the similar or same caliber of that of Hans?
  14. #44
    Jul 2016
    4,116
    Mine will be rigged within an inch of its capabilities and my notes may have more to do with aerobatic properties than hydrodynamics!
    Quote Originally Posted by dmitry100 View Post
    My hull is an older, HPR layup. I have not personally seen one of the new ones up close.
  15. #45
    Sep 2017
    ZN
    86
    I'm not sure how the new ones compare. I'll thake some closeup pics this evening.
  16. #46
    Sep 2017
    ZN
    86
    The quality looks good to me. I've never seen an older older one in the flesh though.20171205_204229.jpg
  17. #47
    Sep 2017
    ZN
    86
  18. #48
    Nov 2011
    SA
    1,837
    Here is one I'm building for a customer
  19. #49
    Jul 2016
    4,116
    Quote Originally Posted by nata2run View Post
    Who makes the rudder hydraulic arms?
    I also see an uneven transition from the tunnel to the bottom of the rudder stand-off. Perhaps this is one of the differences between old and new C5009's.
  20. #50
    Nov 2011
    SA
    1,837
    Me, :-)
  21. #51
    Nov 2011
    SA
    1,837
    @ fweasel, you sure you got a 5009?? ( also see an uneven transition from the tunnel to the bottom of the rudder stand-off)
  22. #52
    Nov 2011
    SA
    1,837
    the yellow is an original 115 HPR from Hans, and the white the 5009 also from hans, same size but different hull type...
  23. #53
    Mar 2011
    BC
    7,629
    The sides of the pedestal depressions are also different. Any other difference my friend?
  24. #54
    Nov 2011
    SA
    1,837
    The hulls have not changed they are different hulls
  25. #55
    Mar 2011
    BC
    7,629
    Yes but are the tunnels and such the same? Does one favor handling better or anything Kent? I know we had discussed that a HPR can handle but I’m curious if any are better? I did not actually know the 5009 was any different. I thought maybe the hatch orsomething.
  26. #56
    Nov 2011
    SA
    1,837
    They are both great, would say the 5009 is more for straight and the 115 handle a bit better
  27. #57
    Jul 2016
    4,116
    Me, :-)
    Can't find them on the site last I looked, and the site doesn't even load for me now. How much/where?
    Here's a shot of the bottom of my hull at the rear. My rudder standoff to tunnel transition is smooth/level. My hull looks exactly like photos of a Bulletproof C5009 that KBB built down to the locations of the hatch bolts and water inlet/outlets.
  28. #58
    Nov 2011
    SA
    1,837
    If you need hydraulic or any other parts you can hit me up
  29. #59
    Sep 2017
    ZN
    86
    Hi Kent
    I'm going to send you a PM.
    Brad.
  30. #60
    Nov 2011
    SA
    1,837
    Brad if easier catch me on FB nata2run
Tags for this Thread
