what is the best motor (brushless), ESC, strut, prop, rudder, and shaft and shaft housing?
any idea that would help..
A wealth of knowledge can be found using the search block in the upper right corner. I don't know what boat you have but I remember seeing right much info on the blackjack 24.
IMPBA 20583
I have a 27" cat that does 92mph on a TP 3080kV motor, 220A Swordfish ESC, speedmaster mini strut, speedmaster 006 mini rudder, ABC 1715, 3/16" flex cable, 1/4" K&N bass stuffing tube
Jopher, we need a lot more information to give you a useful answer.
- what speed do you want?
- what runtime do you want?
- what type of running, oval racing, general sport running, speed runs?
- what voltage do you want to run?
- what size pond do you run on?
- smooth water, ripples, waves?
- what is your budget?
Ray the math says it could have been on 4S....
Yes on 4S
Jopher, the point of my answer was you haven't given us enough to go on, just like my answer really doesn't give you much of a road map either
