Results 1 to 1 of 1
Thread: Stock Zelos twin 80.77mph (130kmh)
    Feb 2017
    na
    726
    Default Stock Zelos twin 80.77mph (130kmh)
    New best speed 80.77mph (130kmh) for my stock Zelos twin. I had to give the Z a little loving today and I had a couple of pretty good test runs with my new 1716 props from Chris (Dasboata). On this run the motor mount came loose and caused the flex to bind up and rub with the tight Teflon liner and caused the ESC to go into thermal shutdown, so I had to limp back to the shore with only full power to one motor. Everything appears ok except the flex. The top recorded speed on this run was 80.77mph (130kmh). Also a BIG THANKS to my "Propsmith" (Chris) again for another AWESOME set of blades!
