Page 1 of 2 12 LastLast
Results 1 to 30 of 36
Thread: Vac-U-Tug
    Sep 2016
    98
    Default Vac-U-Tug
    Decisions, decisions, decisions. Vac-U or Zipp Kitts, pulled the trigger on Vac-U, Phil been great order shipped form Georgia to New York looking at this Monday.
    Anyone has some inside info on this tug? Going to use this as a recovery rig & long day runner.
    Third hull on the bench from scratch, need to clone myself.
    May 2009
    AB
    483
    I've had the Vac-U-Tug and still have a Vac-U-Tow that's been doing rescue work for a few years. The Tow is great, it fits in a toolbox that makes it super easy to pack.
    Namba District 16
    Sep 2016
    98
    Awesome pics, yep - recovery boat will be my intensions. From the homework I have done I'm told 7 hours run time on a 2S Lipo is this possible?
    Might be a runner with my son's Alpha Patrol boat, 2S 5000 Venoms hardcase
    Sep 2013
    NJ
    151
    We also use a vac-u-tug. Have it running on a 7 cell nimh 5000mah venom battery. Just a tad more speed. Ours is more simple, we tow a short length of floating fly line with a tennis ball. Do the wraparound and pull in! Floating line really helps.
    4,116
    I use one as well. I have the bigger brushed motor with the two blade prop and it pushes my bigger boats in fine. The stern rides very low in the water, so if you build a rescue raft for it, it needs to maintain that same attitude or the prop cavitates. I started with a ball and fishing line, but got it stuck in the prop and switched to the raft. I run mine on a 7 cell pack.
    May 2009
    AB
    483
    Quote Originally Posted by rayray9 View Post
    I'm using two 2200 mah 3s lipo's in parallel and have never used more than 25% rescuing for our clubs practice days.
    Namba District 16
    Sep 2016
    98
    Flyfishing line floats right?
    May 2009
    AB
    483
    There are different fly lines some float or sink or have different combinations of sink tips. Usually if it's a bright colour it's a floating line. If your buying a cheap one get a DT (double taper) so you can use both ends. The higher the # the thicker the line.
    My other hobby lol.
    Namba District 16
    Sep 2016
    98
    Good info, thanks.
    Deciding between a pvc pipe / conduit system or a flotation device & drag line.
    Me & fly fishing don't mix, wrestled an alligator once and he won, in New York of all places.
    May 2009
    AB
    483
    I use the pvc pipe rig most of the time, our pond can get weedy and the drag line can get hung up. I just switched the rig over to my Atlantic Tug that is repowered and modded quite a bit but it's faster and has more grunt to get out of the weeds.
    Namba District 16
    Sep 2016
    98
    Aquacraft Atlantic Tug?
    Jul 2015
    701
    Use the tug pulling the balsa float with hooks on it, floating fishing line. Circle dead boat, hooks on float catch the rudder and tow it in.
    Sep 2016
    98
    That thing is crazy, might gaff a shark
    That's one nice tug.
    May 2009
    AB
    483
    Yup, I won it at the Nats a few years ago and put a bunch of stuff in it, repowered with the Fireboat motor, servo controlled water cannons, sound, bilge pump, modified the keel for a bigger prop. It just about does a wheelie taking off. :) I was bored that winter lol.
    Namba District 16
    Sep 2016
    98
    Nice prize on NATS
    Sep 2016
    98
    $330.00 USD prize
    $429.00 USD for the Fire Rescue
    Jul 2015
    701
    Thanks man!
    Sep 2016
    98
    I'm the alligator posting, BTW.
    The original poster is in D.J.'s Locker
    I surf RC boat forums to lure more lunch menus
    Sep 2016
    98
    Prodrvr, the balsa float is custom or purchased like that?
    Going to need 5/16 - 3/8 lettering for this boat, wish to clear coat over white lettering any suggestions or tips folks?
    I'm water cooling this brushed motor - yep. Making notes now before the build
    Sep 2016
    98
    "Scupper", 46 years old - still learning new stuff
    Jul 2015
    701
    Yes sir, it's a 5" Billy Boy Bobbers balsa float. Cheap on eBay.
    Jun 2011
    ct
    826
    Quote Originally Posted by Prodrvr View Post
    what if the boat to retrieve is upside down?
    Jul 2015
    701
    That's the only times I ever have to tow it, is when it's inverted.
    Jun 2011
    ct
    826
    Default vac u tug
    how does the hook grab a rudder that is standing up in the air.
    Jul 2015
    701
    Do you see how big the hooks are? Grabs the rudder, cooling line, strut every time.
    Sep 2016
    98
    Jun 2011
    ct
    826
    very nice. going to order one. I use a proboat recoil 26 and tow a line from a fishing reel attached to my futaba 3pmx. this float will work when the boat is flipped over. been using this retrieval system to retrieve my gas rigger. needed a way to grab my electrics when they flip. thanks.
    Jun 2011
    ct
    826
    where did you find the float with hooks attached to it? I can only find it without hooks on ebay.
    Jul 2015
    701
    I bought a package of 4 hooks at Walmart. Then I bought a package of red antenna caps to put on the ends of the hooks. I bent the hooks open slightly with pliers, then screwed them into the float.
    May 2017
    OK
    1,464
    I've had the Vac-U-Tug and still have a Vac-U-Tow that's been doing rescue work for a few years. The Tow is great, it fits in a toolbox that makes it super easy to pack. Sent from my iPad using Tapatalk
    Does your Tow have the 2-engine and double rudder servo option on it?
