Alright thanks guys, I'm going to run it a few times and go from there! See what needs to be done if anything. I got a little over excited... haven't tinkered for a couple days
Just so you are aware, if you are planning on doing the 300 amp modification the datalogger needs to be recalibrated.
NEVER SATISFIED RACING
Fine Design 32 V-Hull 4082+6s
Update: I ran the ET data logger that I modified with the 10awg wire. It works just fine and the data logger showed a higher voltage level at max amps, so the wire is reducing voltage loss. I'm going to proceed to my second ET now.
Thanks Craig! Good to know it worked out!
Hi All,
Has anyone experienced the Eagle Tree not recording all the temps properly? Every time I run it at least one temp is missing and its not always the same one.
Thanks!
I've had mine not data log at all, when I changed laptops. I had to set up everything from scratch. If it's showing in the live mode, then it should be there... I don't run two temps, so no experience with this specific issue. It's only the temps that are missing? Oh, one other thing, make sure your connectors are solid on the sensor. I think it will not lg if the data logger doesn't see a connection when it turns on. I had that happen on the tach sensor...
Thanks Craig, ya it's weird because in live mode it all checks out.... I'll check the connectors next time.
Strainge..Yes, all Eagle Tree sensors. 1 motor loop and two standard.
