Op, let me give you some info based on my personal experience.
If this is your first build and coming from a spartan, I'd sway you from a rigger. Why? Well they are a very particular animal to set up correctly. They can be hard to tune in. They like to be super light and your big battery of choice isn't really conducive to that fact. They barely float as it is. I'd recommend a cat first. To go 60 with a rigger is pretty easy and 6s is not what you'd want to use.
I see too many people trying to set a boat up based on equipment they already have, like batteries and motors and then wonder why the boat doesn't perform as it should. Should you decide to build this rigger tote talking about, my best recommendation is to build it based on how it needs building and buy the correct gear AND CORRECT batteries that are needed for your boat. It'll save you a headache later.
