Results 1 to 9 of 9
Thread: Hinges for large scale hull canopy?
    Apr 2014
    858
    Default Hinges for large scale hull canopy?
    Anyone know where I can find these hinges, or something similar, in aluminum/stainless steel?
    Sep 2016
    98
    https://www.mcmaster.com/#1803a33/=18ryfqi
    Pin release Quick disconnect hinge, close match
    Apr 2014
    858
    That is close, but I need it to be about 1/3 that size. That one is almost 3 inches wide and just over an inch tall.
    Jun 2017
    TN
    4
    Similar to what you are looking for.
    http://www.dreamworksrc.com/catalog/...-Hinges-2-Pack
    Sent from my SM-G930V using Tapatalk
    Jun 2017
    TN
    4
    http://www.dreamworksrc.com/catalog/...set-Door-Hinge
    Apr 2014
    858
    I can't find dimensions for those. They are close, but I would have to do some grinding and polishing if they were the right size. I've found some other styles that may work, on large-scale helicopter sites. These may be an option:
    They are under an inch in length and about 0.3 inches wide. Just a tad smaller would be better, though.
    Jun 2017
    TN
    4
    Yes they don't list a size. But I believe that they are small, I just don't know how small.
    Apr 2014
    858
    I may be able to find a good scale substitute in eyeglass hinges:
    Apr 2014
    858
    I contacted ManuelW about the hinges in the image I shared on the first post of this thread, because they seemed like his area. Sure enough, he told me he had only 10 sets of those made and they were very costly. So it looks like I'll have to settle for a substitution. I'm going to mock up some example hinges with the same dimensions as the eye-glass hinges I found online. I'll test them on the hull for scale/look and then decide on which set to order. Looks like the Low Altitude boat I'm modeling my build after has two individual hatch hinges anyways.
