Results 1 to 6 of 6
Thread: Zelos strut sleeve bearings change
    May 2012
    IT
    107
    Default Zelos strut sleeve bearings change
    dear friends, i'd like to check and maybe change the strut slave berings...
    how to?
    i've take off strut from hull and now?
    i think i have to remove the 12mm dice around the ball joint but it's blocked...
    am i right?
    thanx to all
    HPR 115 kevlar bulletproof @90mph, MHZ Rapid carbonfiber, Bingo Race Minieco
    Futaba AIR TX/RX system with telemetry
    Apr 2016
    Ca
    451
    The ball is threaded. Unscrew it. Carefull drilling out the brass sleeve the drill bit will want to grab.
    May 2012
    IT
    107
    Sorry but i do not understand well...
    What i have to unscrew?
    What i have to drill? The bearing to pull it out? From where?
    It is crazy no pics all over the web.. damn...
    Apr 2016
    Ca
    451
    Unscrew the ball. I used a paper towel and pliers. If you want to pull the sleeve out you might be able to tap it out with a punch but I drilled mine with a drill bit.
    Apr 2016
    Ca
    451
    And the "dice" should unscrew too.
    May 2012
    IT
    107
    wow so difficult...
    anyway from where i have to unscrew the ball?
    the dice is blocked... crc and a lighter to make it hot just done.. no way...
    i've some brand new sleeve bearings... maybe they don't fit...
    i've start this job coz i found a black stripe at the end of the drive shaft...
