Leak in Prop Liner
Zelos 36, stock stuff tube, stock liner, OSE cables - This is strange. I was just preaching to Vinny to put his boat in a tub to see if any leaks could be detected. I've had a leak problem for a while so I did the same this evening. No motor running, just floating. It took about a minute but after that there was a steady drip (about every 2-3 seconds) coming from the liner in the stuff tube.
1. I just lubed the shaft before doing this.
2. The stuff tube is bent slightly upwards. The end is higher than water level. How the heck is water managing to rise above itself?
3. The drip is so consistent it's almost like there was pressure pushing it thru.
I'm stumped.
May your batteries never fail you...
Mike
