Originally Posted by
NativePaul
Even with only 1kw to play with, a good proportion of the Super Evils that I have seen racing internationally have their sponsons modified to reduce aero lift with thin sheet spoilers following the line of the inside edges of the sponsons, over about half of the area where the bulk of the sponson drops away. As you are putting about double the power into it I would heartily recommend doing at least that to reduce the amount of blowovers you have. I would make sure that the range of AoA adjustment goes under the recommended 5deg as well as over it too.
Is there a picture of this, or perhaps a drawing?
