Results 1 to 27 of 27
Thread: Strut bushings
    Jul 2017
    34
    Default Strut bushings
    what are people using for strut bushings these days? My ovalmaster uses ⅛ strut. Im currently using the diy bras tube cross drilled system with a bronze bushing I scalped from a motor. Need a new one now so?
    Cheers
    Jul 2017
    34
    So guess Im just building the same bushing again.
    I use oilite motor bushing from a 540 motor. I used to pop em out and put bearings in all the time so a few kicking around.
    I press it into a brass ¼ k&S tubing after turning it down on my lathe to fit tightly then use sleeve retainer as press it in. The other pieces will also be glued in and cross drilled after gluing . I will use cooling fluid during drilling so I don't destroy the sleeve retainer bond. I will have small teflon washing between the drive dog and strut bushing end.
    All done
    May 2017
    OK
    1,464
    Bushing_Assembly_Inside.jpgBushing_Components.jpgStrut_Assembly.jpgStrut_Bushing_Assembly.jpgStrut_Components.jpgLooks like you and I are going down the same path... I have a Speedmaster 21 strut on my 34" Hydro with a flex shaft, no liner. The problem with the parts they give you, is that there is no way to allow for the 0.175" of space you need between the strut and the prop shaft dog, to take up the shortening of the flex shaft under heavy load. The bushing that came with the strut seems to be suited for a straight shaft, where you can use thrust bearings and collars to set up the proper end-to-end clearance. I ran the boat with the space cut down to 0.075", and the boat started to plow on the bow, due to the shaft moving the strut to positive thrust angle. I set it up to the right clearance, and the bushing nail head just falls out of the back of the strut, making for horrible side-to-side play! I solved it by modifying the components as the pictures show. I placed the original strut bushing into a piece of 1/4" copper tube and soldered at the appropriate place. I put a hole into the side of the copper tube to put a 6-32 grub screw in to seal the hole and keep the strut bushing assembly in place. After the run, I just take out this screw and squirt some lubricant in there. Now the shaft can move up as it needs, and the strut bushing stays wear it should. It ran like a champ!
    Sep 2007
    Co
    3,915
    I have always used Ball Bearings, this is my newest setup in a Stainless steel strut.
    Randy
    BBY Racing
    Jul 2017
    34
    Really nice design with the set screw.
    My bushing is press fit (firmly) and set with med thread locker.
    The main bronze oilite bearing is external on the bushing.
    You need to heat it up with a pencil torch to break the thread locker to remove .
    But it's only 1/8 shaft and .098 cable.
    Jul 2017
    34
    Quote Originally Posted by RandyatBBY View Post
    Randy that is sweet.
    What size bearings did you find to use for that?
    My ovalmaster is 1/8 shaft and .098 cable , but the b24 I plan on building up will be 3/16 shaft. Bearings would be nice. Although the TFL outdrive could be really cool too..
    I guess it depends if I want a regular system for steerable strap system which may or may not be the best fit for the whole even though it looks scale appropriate?
    May 2017
    OK
    1,464
    Randy, I was wanting to do the same thing, but couldn't find bearings. There's a bunch f metric stuff that is close, but was lazy to machine anything! So the shaft can move freely in the copper tube and the tube is held in place by the inner races of all the bearings in line? Did you have to bore out the hole in the strut to accommodate the bearings? Very nicely done!
    May 2017
    OK
    1,464
    RC, is that a flex shaft or straight shaft? I don't see any take up space between the strut and the prop dog... That was the problem I was trying to fix... my flex shaft winds up at least 0.15" under heavy acceleration.
    Jul 2017
    34
    It's flex shaft, the There is plastic washer that has a bend in it like a ) it flattens when the cable tightens. I have checked to make sure there is some slack but it is hard to see.
    May 2017
    OK
    1,464
    Yes I see that... But my flex shaft is winding up much more than that. It accelerates really hard on 8s. I like that bearing setup you got! It's neat to see different people's solutions to problems. It's what I like about this forum...
    May 2017
    OK
    1,464
    Randy, what distance do you set your prop dog from the back of the strut?
    Oct 2013
    la
    8,740
    The bearings you need for a .187 flex is a r156 (there's different variations of that number depending on if it's sealed or not). I get mine from boca.
    9,400
    Interesting....
    9,400
    I have always wondered if the collar on the end of the speedmaster bushing should be inside the aluminium strut Oron the outside?
    I've been running them on the outside for years and may change this now after seeing your post.
    Thanks.
    Jul 2017
    34
    8S I bet it does. I ight have to revisit my gap on the drive dog now that I look at it closer. Have not run yet since I made the new bushing.
    My ovam21 is running a vintage 2002 Lightning Man Neo 05 motor not quite the same power plant although very torquey motor. It is difficult to turn the shaft by the prop it cogs so much, still a very fast boat especially with x438 prop on 2s.
    2,728
    I use ball bearings too. The cheap Chinese 1/8" strut has just enough diameter to drill out for 1/8"x1/4" ball races. I chop the tapered nose off just short of the strut blade, and hand drill each end using a regular bearing on the front and a flanged bearing on the back, it leaves a paper thin wall thickness around the bearing pockets, but has proved to be stronger than a .98 flex cable. It looks like your existing strut has a larger diameter and would be easier and stronger to drill out, maybe even having enough meat that you could use a good pillar drill or mill, and drill a long bearing pocket from the back to preserve the taper at the front of the strut.
    CraigP, if when you pull the nail head out you are getting terrible side to side play, then either the floating bushing and/or strut have worn out, or were machined to the wrong size. Your being able to add a 1/4" tube to it without mentioning drilling it out makes me think that it had a 1/4" bore and the only bearing surface in it was the small 1/4" "nail head" at the back. Putting a grub screw in a 1/4" tube soldered to the floating bushing to stop the floating bushing moving defeats the whole point to having a floating bushing. Better would be to extend the "nail head" to the .175"+ that your setup needs with a tiny length of 1/4" tube (soldered or not), and then add the 1/4" tube you added, but a tiny bit shorter to compensate for the extra "nail head" and drill a hole in it and the strut for a grub screw, but not solder it to the floating bushing, and not put the grub screw right through it into the floating bushing. That way you still have a working floating bushing, the nail head can not come out, and the bearing carrier can't disappear up your stuffing tube. Either that or use a matched strut/bearing system.
    May 2017
    OK
    1,464
    That's a good idea Paul. Since the last post, I modified to use (2) 1/4" X 3/16" bushings, the ones available on OSE site. The bushing I did was working very well, but there's something else really bugging me... you guys will probably think this is ridiculous, but I have to do something. I left nitro boats because of the oil contamination in the water while running it. When we had a bunch of boats running together, it really made a mess! Now, I'm losing grease out the back and polluting the water again. I want to minimize this to the absolute degree I can.
    I have a good seal where the stuffing box enters the front of the strut. I use a piece of silicone tubing to go over the point where they meet. The action of the flex shaft acts like an Archimede's Screw, pumping grease towards the stern. This is good since the radius in the stuffing tube is towards the back and that's where the highest heat rise is.
    Sooo, I ordered some small lipped shaft seals to put in the back of the strut to contain the grease. I have to open the diameter on the back end to 5/16" to press fit in the seal. The pressed-in bushings dropped the grease leak by more that half and has a great bearing feel to it. The whole thing is made more difficult due to the flex shaft shrinkage. The prop shaft has to float back and forth. I've thought of the bearing setup Randy posted, but I would have to have the inner races tight on a piece of tubing and then let that tubing float on the prop shaft. In the end, not much different over all the other setups discussed. Only a lip seal will hold that grease back.
    Anybody else feel the same about this water contamination issue? I'm not a "green guy" in the traditional sense, just hate seeing oil marks coming off the back of my boat!
    May 2017
    OK
    1,464
    Here's a pick of the silicone seal on the front. You can make out the clearance needed on the back...
    Sep 2007
    Co
    3,915
    I have seen this done with shrink wrap a little thinner application.
    Randy
    BBY Racing
    May 2017
    OK
    1,464
    Shrink wrap is what I should use with a bit of silicone underneath.
    May 2017
    OK
    1,464
    Well, it's time to eat some crow... I decided to use a SS tube for the stuffing box because the clearance was tighter. Looks like I have created a very efficient screw pump with the grease! Looks like my grease pumping problem is probably much worse than what others are experiencing, due to the tight clearance that I put in there... Thinking of changing to a 0.150" flex and use a teflon liner. OSE is flat out of stock on all those parts, except reverse cables..
    May 2017
    OK
    1,464
    Default Strut sealed, grease leak mitigated...
    I got the seal into the back of my strut as I was talking about. I ended up using a EPDM Rod U-cup seal. It has a 3/16" ID and a 5/16" OD. It's about 1/16" thick in the cross section. I milled a counter bore into the back of the strut 0.060" deep for the U-cup to sit in. Since this isn't a metal cup seal, it is not press fit. I fashioned a small metal place and affixed it with two, 2mm SS socket head screws to hold the seal in and compress it slightly. I am losing very little grease now. I ran it, and didn't have to lube at all over the course of 4 runs. I dissambled when I got home, no water and the grease was fine! Propbably could get many runs before servicing the shaft. I'm using ProBoat Blue Marine lube with Marvel's Mystery Oil mixed in. The two lubricants seem to "get along" just fine. Pictures below...
    May 2017
    OK
    1,464
    Randy, water got into the strut with heat shrink, even with silicone applied. I'm not getting any water with the silicone tubing. A bit strange, since it hangs in the water more than thin heat shrink... I think the heat shrink is peeling up, letting water in.
    2,728
    You can get heat shrink tube that is lined with a hot melt glue, I use it for attaching boom tubes on riggers, it is thicker than normal heat shrink, but much thinner and much more secure than silicone tube.
    May 2017
    OK
    1,464
    Hmmm, haven't heard of that, I'll look around for it. Is it still pliable after shrink? I use different angles on the prop for different props. My M445 likes some positive angle and all my lifter props like negative. All in, I need about 3-4 degrees of freedom at the joint.
    May 2017
    OK
    1,464
    Update: I replaced the SS tubing on the stuffing tube, put back in a K&S brass 1/4" tube, traditional approach. I went back to the 3/16" flex shaft, no liner. The 0.150" flex was too springy, it won't take 8s torque for long. The whole SS tubing thing was a bust! DO NOT try that! The heat buildup in the stuffing box was way too much! I'm sure I was the only one foolish enough to try... BTW, you can get brass tubing at your local Hobby Lobby store. Not sure why OSE seems to have trouble keeping that in stock...
    Dec 2015
    OR
    31
