Page 1 of 2 12 LastLast
Results 1 to 30 of 35
Thread: Another one from proboat?
    Jun 2015
    Wi
    734
    Default Another one from proboat?
    Just noticed this on Facebook, now I know why the geico was discontinued
    http://www.proboatmodels.com/Product...rodId=PRB08029
    Mar 2016
    BZ
    970
    Just saw it as well. Looks very nice!
    Oct 2016
    pa
    476
    yup, seen it too .Rafael was driving a sample boat
    Oct 2013
    la
    8,740
    That thing is sick looking!
    Apr 2016
    451
    Does have a nice silhouette. Looks clean in the water.
    199
    Pretty cool looking!
    Jun 2015
    Wi
    734
    I agree, I have 4 green boats Lol but I really like the scheme on this one. Great job ProBoat. On a side note I noticed it has a flat bottom strut. Interesting
    Jan 2015
    470
    Running video is on the Pro Boat Facebook page.
    I'm loving the flat bottom struts lately. I've been putting them on most everything. It makes the boat so much more responsive to strut adjustments. It acts like a trim tab and helps provide a good amount of transom lift.
    Rafael Lopez
    Product Developer-Pro Boat
    4,125
    Looks like I found a break away rudder replacement for my Impulse 31 V3.
    Jun 2007
    1,515
    The strut rudder combo looks terrific. Really like the one piece strut bracket. Will make an excellent combo for the small transom footprint of a rigger. We just need the part numbers to be corrected since currently it is listed as the same as the the UL-19, which cannot be correct.
    Jun 2015
    Wi
    734
    Quote Originally Posted by Rafael_Lopez View Post
    Running video is on the Pro Boat Facebook page..
    I saw that later in the afternoon yesterday, ride attitude looks completely different than a geico/bj. Looks great out there. 60 mph is awesome out of the box, is that prop untouched too?
    May 2017
    OK
    1,464
    This is a beautiful boat! Sure wish it was out before I got into the DF 34 Hydro... The sponsons on the ProBoat look much more correct and would have saved me a ton of work on the modifications I put on the DF Hydro. Oh well, next build....
    Oct 2013
    la
    8,740
    Quote Originally Posted by Mxkid261 View Post
    I talked to Raphael yesterday, that is with an untouched prop
    Jun 2015
    Wi
    734
    I assumed so. Pretty good out of the box
    May 2017
    OK
    1,464
    The add says it's a stainless prop, so probably cut very close on the CNC, then just blade balanced working the spines of the blades. I'm so it's hand sharpened by someone... At that speed, if it weren't balanced and sharpened you'd think it would do some driveline damage.
    I want one!
    Oct 2013
    la
    8,740
    I want one!
    It's not made on a Cnc. They are cast stainless props and they aren't too bad as they come but they can definitely be improved. With my zelos it was 10mph faster than all other boats with stock props vs mine being sharpened and balanced.
    Don't put too much emphasis on thinking that a slight imbalance will hurt anything. It would do some damage if the prop was spinning out of the water at all times, when you put the prop in the water everything changes. When I s/b my props I try to get them as balanced as I can but I won't waste lots of time trying to get them perfect. I don't have any driveline failures that I can recall. I've only snapped two flexes in my boating that I can recall. One was a stock impulse shaft on 6s which were known to have issues and the other was my first attempt at making my own flexes, I used the wrong solder on that attempt.
    To be clear, a small imbalance has not mattered in my experience. A large imbalance would be worth correcting. The stock proboat props are not far off.
    199
    And my Blackjack lol
    May 2017
    OK
    1,464
    Cast prop... Man, that SS is tough stuff to rework! Yeah, my little mag balancer can only get it so close anyway. Funny story: I found an old JG 1-25 prop from my old nitro boat. This was from my early twenties... I had a 0.40CI engine in a 36" hydro, ran like a bat out of hell! But it kept eating universal joints, before flex shafts. I checked that prop on my balancer and one ear was so heavy on it. I could then feel the differences with my fingers... I ended up almost de-tounging that one ear before I got it even close to balance! Then I read on the internet that the Dumas props where notorious for coming out of the mold with a thick ear... I found that statement to be true, for sure
    WA
    8,335
    Prepped Pro Boat Zelos 36 "Cast" Stainless props... Not too bad using a Dremel and cutoff wheel to do the main thinking and material removal...
    Darin E. Jordan - Renton, WA
    Apr 2016
    451
    Agreed. When running you would think with a surface running prop the load is always pushing up from the one blade. Id think matching size and shape of modded props is more crucial.
    Apr 2017
    191
    I wish they would stop worrying about new boats quite so much and focus on supplying parts to existing models
    May your batteries never fail you...
    Mike
    May 2017
    OK
    1,464
    Agreed Mike.. They are losing sell opportunities. I have had to go to other shops on quite a few items needed for my hydro build. There's a lot of goose eggs fro quantity available on the parts site!
    Apr 2017
    191
    I have one boat barely working, another on the sideline until parts arrive.
    Mike
    May 2009
    on
    236
    Quote Originally Posted by mikiek View Post
    Totally agree with the above statement.
    Jun 2017
    Mi
    5
    I have a river jet sitting on the shelf waiting for impeller should be here in aug and hull in September.maybe build some parts proboat!
    WA
    8,335
    Quote Originally Posted by bigcam406 View Post
    Chevy doesn't make parts for the 2nd Gen Camaros any longer. Just sayin'.
    On every level, the new Veles 29 is a superior boat to the existing MG29/BJ29 series of boats. Just the natural progression of development.
    Jun 2017
    Mi
    5
    Didn't they stop making 2nd gen camaro's 35 yrs ago are we are not talking about 35 yr old boats.it seems the manufacturers put little effort in parts support and just focus on rtr's. And this applies to a lot of manufacturers lately not just pb
    WA
    8,335
    Quote Originally Posted by Livnonthedge View Post
    In RC-Hobby years, it was just yesterday! :)
    Honestly, it's all about "being profitable". Bean counters and business majors decide how much support to provide and for how long. NOS sitting on the shelf doesn't lend itself to staying in the black. Sorry, that's just how it is.
    May 2017
    OK
    1,464
    Guys, you just have to get good at adapting other parts/components to your builds as it is required. Think of what the car guys in Cuba have had to do, in many instances, make parts! There are parts out there that will fill the bill, but may not be drop in...
    But the fun is "making" your boat work, right? Fabricating is the biggest thrill I get out of them. I like running them, but building the boat is king! They are always going to stress RTR's, but RTR's will never be as fast as a boat that someone has built for a specific goal. And you can't get bad-ass fast just running and supporting RTR's. I guess I just have a pet peeve about running stock boats...
    Apr 2017
    191
    I'm needing parts for a Zelos 36. If ProBoat thinks that's too old to build parts for I'll be looking elsewhere for any new boats.
    Mike
