Results 31 to 60 of 74
Thread: Stuffing tube
  1. #31
    May 2017
    OK
    1,464
    I'm not sure what the wall thickness is on that tubing... it's not as tough as brass. To be safe, stick with brass. There are many hobby shops on line that carry it.
    BTW, way to go on the Dremel purchase! I just made up a 0.150" flex shaft to 3/16" prop shaft assembly. Used mine to cut the ends, sure works great!
  2. #32
    Aug 2016
    As
    48
    Same thickness as brass tube 😛
  3. #33
    Aug 2016
    As
    48
    Is this right? Now the tube is all the way into the stinger.
  4. #34
    May 2017
    OK
    1,464
    You need the bearing system for the prop shaft in the stinger. The stuffing box just needs to go in about 1/4" and sealed off from water penetration. Are you using roller bearings, floating bushing or pressed fit bushings in the stinger for the prop shaft? I've done them all, and like press fit teflon coated bushings and use 3 of them. Get two of them as far to the ends as you can and put the third in between them.
  5. #35
    Aug 2016
    As
    48
  6. #36
    Aug 2016
    As
    48
    Dobyou have pictures of the systems you mention?
  7. #37
    May 2017
    OK
    1,464
    I posted pics on a floating bushing about a week ago. I don't have bearing pics, but that post had pics that someone posted of bearings and where to get them...
  8. #38
    Aug 2016
    As
    48
    I feel like a noob now... What is actually a bearing? Do i have to use it? I tought the struts i bought from OSE where ready to be mounted on the bost... no need for modifications.
  9. #39
    May 2017
    OK
    1,464
    Search for a thread called Strut Bushings.. Good stuff!
  10. #40
    Aug 2016
    As
    48
    So i can cut the stuffing tube where the hull ends?
  11. #41
    Aug 2016
    As
    48
    Found the thread. Looks nice! I think i will just mount the struts and dont use bushings... what can go wrong? Why do you use bushings?
  12. #42
    May 2017
    OK
    1,464
    I checked your part number, it comes pre-installed with lead-teflon bushings, the same I'm running, so you're good. Just put the stuffing box in about 3/16-1/4", seal the stinger to the transom with silicone and you're done!
  13. #43
    Aug 2016
    As
    48
    Thanks for all the help Craig! Really appreciate it. As you can ser im kinda new to this... i will put the stuffing tube 3/16-1/4 outside the hull and the seal it.
    Thanks again!
  14. #44
    May 2017
    OK
    1,464
    Kristian, remember to de-burr the stuffing tube inside and out. Get all that cutting debris off of there. It can get into the grease and cause excessive wear. Clean everything real good on final assembly! I use acetone on a rag to get parts cleaned.
  15. #45
    Aug 2016
    As
    48
    Is this right then?
  16. #46
    May 2017
    OK
    1,464
    The stinger has to be flush with the transom, so if all that goop around the stuffing box isn't soft, you'll have to clean it up before mounting the stinger. I assume this pic was taken with the sealant just applied and the stingers ready to go on. Nice boat! I hope your ready for that, because she's going to be a handful! Looks like a zipper!
  17. #47
    Aug 2016
    As
    48
    Hehe thanks! The stuffing tube is already glued in place 😊 Stinger will flush!
  18. #48
    Aug 2016
    As
    48
    Almost done! Just some adjustments and watercooling left :)
  19. #49
    May 2017
    OK
    1,464
    Sweet! I want one!!
  20. #50
    Jul 2015
    701
    Kram - why did you mount those motors so far forward?
  21. #51
    Aug 2016
    As
    48
    Because i used som motor mounts where the angle of the flex cable would be too much... The motors are mounted like 10cm more to the back than the stock setup 😛 Pretty happy now so dont judge! Hehe
  22. #52
    Aug 2016
    As
    48
    Tried the boat now.. Fast as hell!
    One stinger got pretty hot... i greased the cable alot but i cant figure out what the problem is. I only ran the bot for like 5min to test it. Should not be that hot!
  23. #53
    May 2017
    OK
    1,464
    Usually the stinger is not on center to the stuffing box. This causes the flex shaft to rub the stuffing tube. Also, check that there is enough grease in the strut, for the prop shaft to strut bushings. And, make sure you are using the right flex shaft on the appropriate side. You need a left turn flex shaft on the left side and a right turn flex shaft on the right. Stingers are water cooled, so something is very wrong for it to be so warm after pulling in out of the water.
  24. #54
    Jul 2015
    701
    Stainless Steel ... It is much harder to bend. Don't even think about it unless you have a hand-help tube bender with 1/4" rolling wheels installed in the tool. I hope that helps...
    I had to revisit this comment after getting some stainless tubing for one of my boats. Have you worked with it to pass that comment? I found it extremely easy to bend by hand on a 10" radius wood block. . It bent up a lot nicer than brass tubes.
  25. #55
    May 2017
    OK
    1,464
    Yes, I had it installed and ran about 15-20 sessions on it... I was trying to bend by hand. I didn't have a 15" radius, which was my goal. I took it out because the clearance was too tight and it was pumping all the grease out the strut very quickly. It forms a very efficient screw type pump.
  26. #56
    Jul 2015
    701
    What ss tube were you using?
  27. #57
    May 2017
    OK
    1,464
    The 1/4" available at OSE. It says it has a 0.028" wall thickness. That's 0.012" thicker than the brass. So, 0.024" across the diameter. I tried sanding down the 3/16" flex shaft to make it a little less of a pump, but to now avail. Went back to a copper tube and the additional clearance stopped the excessive pumping action.
    Note, I have a lip seal on the back of my strut to stop grease leakage altogether. It was still pumping grease past that seal! Now, no loss and no water. I only need to service the flex shaft about every 15 runs or so. If you stop the water from coming in and the grease from going out, it is a very stable system.
  28. #58
    Jul 2015
    701
    Oh. I bought .055" wall ss tube. Not from OSE.
  29. #59
    May 2017
    OK
    1,464
    Oh man, does the flex shaft even fit?
  30. #60
    May 2017
    OK
    1,464
    And that was easy to bend you say? I guess I gotta hit the gym!
