Page 1 of 3 123 LastLast
Results 1 to 30 of 74
Thread: Stuffing tube
    Aug 2016
    As
    48
    Default Stuffing tube
    I have two 3/16 flex cables that need brass tube. Should i go for no teflon liner or with teflon?
    What size should i use with no teflon liner?
    Please... i need help 😊
    Aug 2010
    uk
    2,887
    Using K&S brass tube you need 1/4" o/d tube with no liner, using Octura liner you want 9/32" o/d brass tube.
    Aug 2016
    As
    48
    Should i go for with teflon liner or without?
    Aug 2010
    uk
    2,887
    You will get 2 trains of thought on this, some say they don't use liners as its 1 less things to go wrong due to flex binding & melting the liner. Others use liners & have had no such problems.
    Aug 2016
    As
    48
    The 1/4 tube feels a little to big for the 3/16 cable... but i will use it if its right!
    Aug 2010
    uk
    2,887
    If you go to OSE Parts Store @ the top of this page, then on the left hand side you will see flex cable parts. Go into that & you will see all the recommended sizes of K&S tube both with size needed for use with a liner & also no liner.
    May 2017
    OK
    1,464
    Kram, I'm building a DF Vortex 34 Hydro and I installed a 1/4" Stainless Steel tube. This tube has a 0.028" wall thickness which leaves about 0.005" on all sides to the 3/16" flex cable. I use an anti-seize compound as a lubricant. There are all kinds of recommendations on this site for specific lubricants.
    I too did not like the sloppy clearance of brass tubing. Also, brass has a much higher stiction factor, which is a measure of a complex friction. In plain words, it means the "stickiness" of the metal. Stainless Steel is much lower... It is much harder to bend. Don't even think about it unless you have a hand-help tube bender with 1/4" rolling wheels installed in the tool. I hope that helps...
    May 2017
    OK
    1,464
    Oh, and I don't run a liner...
    Jul 2015
    701
    That's gotta be one of the last things you want to use as flex shaft lube.
    Cool
    "Stiction" is not an issue as long as a good lube is used. Anti-seize is not one of those, it is designed for non-moving parts. Plus 0.005" is far too small a clearance between the cable and the tube. When it is spinning under load the cable winds up somewhat, and restricting that too much will add considerable drag. Whether one "likes" more clearance or not, it works well and has been used on hundreds of boats successfully. Most of my SAW records were set running cable in brass tubing, the fastest with 3/16" cable in 1/4" tube. I have never replaced a stuffing tube due to wear, even on boats which have been raced six heats a month of years.
    Lubes which are designed for high speed rotation should be used. There is a plethora of marine greases and automotive oils available - use something which is designed for spinning parts. Hundreds of boaters are not wrong on this, and re-inventing the wheel is not required.
    May 2017
    OK
    1,464
    This is all great stuff... I did test the flex cable on the bench by winding it up manually, putting a 3/4 turn of windup on it. The cable actually gets smaller by 0.006" - 0.008", so it twists up tighter and smaller. So far, I'm having very good results with the SS tube, but I can swap it out if troubles appear. I misspoke about anti-seize compound... You are all very right about that. I was in a hurry and just typed that out. I'm using an engine Assembly Lube, a MoS2 compound meant to go on bearings, piston skirts and cam lobes while assembling the engine to provide break-in lubrication on initial startup and run in. It provides superior metal surface protection, where the two surfaces have to mate to each other. It's a U.S. Lubricants product. I add a 50wt racing engine oil to the stuffing tube/flex cable via the oiler port on the Shaft Tube Steel made by Aeromarine. A lot of people claim it doesn't work, but I feel they are not applying it correctly to their boat. I works great for me... The oil is important to properly disperse the MoS2 Assembly Lube, but that's all I have to do between runs. At the end of the day, just back out the flex cable, clean with acetone and the stuffing tube. I store it dry and re-lube before I run again.
    Oh, something I found works great... I cut off the head of a Q-Tip, soak it in acetone and force it thru the stuffing tube with the flex cable. Two tips cleans it like new, gets any residue out of there.
    Aug 2016
    As
    48
    Thanks guys!
    I will try to run the boat with 3/16 and 1/4 brass tube with or without liner! Waiting on some teflon liners from OSE. But what should ido?? is it more things to go wrong when you dont use a liner? i really dont know... first boat im building...
    Currently rebuilding the genesis with carbon fibre layers and new paint! Miss geico is the plan.. Quite excited to see the outcome :)
    May 2017
    OK
    1,464
    Many folks run liners, many record holders... But, many don't. I don't, didn't want the possibility of the liner spinning in the tube, twisting then grabbing the shaft. But I think it really comes down to good, consistent maintenance and using the right lubes. Many good lube recommendations on the site. Seems most run liners, so if you don't have a clear vision for what you want your driveline to do, I'd go with the liner. Plenty of guidelines for running and maintenance on the site...
    Less to go wrong with no liner - 15+ years experience without Teflon, never broke a cable with no liner, never wore out a brass tube either. That's dozens of my race boats, not including many dozens more of fellow club members' boats.
    The bottom line is that either will, and has, worked well if run properly. Anyone who claims otherwise either has not run them correctly, or only has limited experience.
    May 2017
    OK
    1,464
    There you go! OSE is out of liners, so there's a sign too! Gotta go with the flow...
    Aug 2016
    As
    48
    Hehe!
    When i mount the two stingers, should i keep the brass tube or teflon liner some cm or mm outside the hull? Like when you ser the genesis form the rear, you can see the tubes outside the hul... my english is not that good... haha
    May 2017
    OK
    1,464
    The brass tubing comes thru to the outside of the hull and mounts inside the strut, mounted on the transom. The length of the tube depends on the strut hardware you use. Inside the boat also depends on the hardware you choose. Some ESC mounts have a stuffing box support. The stuffing box support can be separate from the ESC mount.
    Search on this site for the hull type you have. Folks have posted pictures of their builds to give you a sense of what to do. If you're not the mechanical/fabricator type, then you should really look to a RTR boat to start and get hands on experience. For most of us, figuring it out IS the fun of the sport!
    Aug 2016
    As
    48
    I tried to look at genesis builds, but i cant see what they did with the tube outside the hull.
    I have two 110mm stingers, and when i put the tube inside the stinger, the tube will be many cm outside the hull... is that right? 😆
    Apr 2008
    Pa
    20
    running liners in both my boats but I am very strict on greasing the shafts after every 2 or 3 runs.
    I have a twin electric mono and its liners are snug on the drive shafts and I grease them up allot also.
    I heard a while back somebody say that the liner makes the boat quieter.
    not sure how true that is cause I have never run any of my boats with no liner.
    And yes I have brass tubes with .187 cable
    Aug 2012
    VA
    25
    Should liners be snug in the brass tube, I think yes but I have melted the end of one of my liners, the replacements I bought are perfect ID for my flex shaft but the OD is about 1mm shy so it moves freely in the brass tubing any thoughts on using this. If I don't use a linger, my brass tubing ID is like 9/32 but my flex cable is only 3/16.... lots of space in there based on the different sizes. Any suggestions or thoughts. I would love to order 5mm (or 3/16) ID teflon with OD of 7mm (9/32) having a heck of a time finding anything online.
    May 2017
    OK
    1,464
    Try Kintecracing.com... OSE has virtually no stock, except a bunch of reverse stuff.
    Nov 2008
    DE
    2,322
    I run and race with both....P-Lim system = .150 cable and teflon. Full P or bigger gets .187 flex with no liner. 1/4" brass for both. Just keep 'em lubed!
    "Will race for cookies!"
    IMPBA D12
    My Gallery: https://forums.offshoreelectrics.com/album.php?u=1738
    Aug 2016
    As
    48
    Thanks for all the answers!
    I have a 6mm stuffing tube with 3/16 cable. Gonna use 6mm with no liner i think.
    I will put the stuffing tube all the way into the stinger, and then bend it. And glue it off course... So the stuffing tube will sit a lot of cm outside the hull.
    What do you use to cut flex cables?
    May 2017
    OK
    1,464
    You should solder the end to be cut, then use a high speed cutting wheel, like a Dremel tool. The soldering keeps the end from unraveling. I assume you are cutting where the cable meets the motor coupling...
    Aug 2016
    As
    48
    I dont have s dremel... what else? 😛
    May 2017
    OK
    1,464
    I have a large pair of lineman's pliers, that have a hefty cutting wedge in them. I used that successfully on my first shaft. I then used my table grinder to clean it up.
    May 2017
    OK
    1,464
    Kristain, you need a Dremel tool. A very handy thing to have! I have the Drexel 7700 battery powered. I ordered some 1500mAH battery packs as extras.
    Jul 2015
    701
    A Dremel is a "must have" in r/c.
    Aug 2016
    As
    48
    Bought a dremel! Dremel 8100 😊
    Aug 2016
    As
    48
    Can i use aluminium tube?
