Results 1 to 5 of 5
Thread: Battle Damage.
    Nov 2008
    Ql
    3,169
    Default Battle Damage.
    Last weekend I flipped my 6s sports hydro. As the boat hit the water poor Ash, who was immediately behind me & just to the outside, had no time to react & his left sponson speared through the belly of the boat.
    Luckily he was able the continue the race. I still feel bad about the damage done to Ash's boat, the 'Woody'
    When I went out to retrieve the upside down hydro I saw the hole as an easy fix with some tape ready for the next race.
    It was a different story when the cowling was removed however.
    The sponson had broken the motorshaft, mangled the flex & stuffing tube, & bent the motor mount. She was out for the day.
    Just couldn't believe that the motor shaft could be broken like that.
    All fixable of course but here are some pics.
    The boat in pristine condition before the race.
    The hole in the belly.
    The broken shaft, & drive line damage.
    The sponson damage to the 'Woody'
    Another view of the 'Woody'. It was such a beautiful boat too.
    Apr 2017
    QL
    1,038
    Paul, the good part is atleast the damage is under and not visible so the repair will never be spotted unless you tip it over.
    Nov 2008
    Ql
    3,169
    That is a plus rol243.
    A bit of 1/16" ply & some silver paint to match the sponsons.
    Hopefully the motor will only need a new rotor & a set of bearings.
    Nov 2008
    Ql
    3,169
    All fixed now.
    I simply squared off the hole & epoxied a patch in flush, with a larger 1/16" ply plate over the whole thing.
    I've put a Tenshock 6 pole 4074 1550kv motor in it to try it out in our EB (6s ) sport hydro class.
    May 2017
    OK
    1,464
    That’s what it’s all about! Race them hard and fix them good!
