Results 1 to 3 of 3
Thread: twin mounts
    Jun 2011
    ct
    826
    Default twin mounts
    installing twin mounts on my avenger. was going to tack in with ca, then use jb weld to attach to hull. I'm worried that the jb weld will run and pool at the base of the mount. any info appreciated.
    7,630
    You can use tape along the hull 1/8" from mount. Just pull tape before JB cures but after it is runny. I think Travis has a thread on this for servo mounts, I have it in a build somewhere as does properchopper Tony.
    9,402
    If you do one side at a time you can wedge the hull flat so it doesn't run.
