Have you guys surfed this page?
http://www.castlecreations.com/suppo..._boat_apps.pdf
Steven Vaccaro
Good info!
Very good info and it was prepared by Brian Buass "The Snowman" and he knows how to destroy an ESC
Douggie
Looks like large boats are not covered under warranty at all. I like that they recommend running 2P regardless of hull size, to make sure voltage drop will not destroy an ESC. That's what took out one of Hydra 120 HVs i ran with KB45 motor in my big hydro. I have been asking Castle for a while, to start releasing articles and tutorials how to set up a boat properly. They need to release an article written by their engineer about how and why ESC's fail.
What is wrong with 1P. The voltage drop will be the same regardless of 1,2,3,4P. The difference is available amps
Darin E. Jordan - Renton, WA
Darin, this makes no sense. Each cell will deplete it's own voltage to what it was charged at. If the cells are not balanced ...problems...and this will increase with multiple cells and you do not have a device on board that will measure each cell's voltage.
Douggie
My Fellow Canadian;
What I think Darin is saying ( I could be wrong) is that with 2 packs in parallel, the controller will see less voltage drop because its sucking power from 2 packs and they will be able to "balance the load" better than a single pack. You would be sucking power from 8 cells vs 4 cells and the 8 would provide a more stable voltage source.
The more cells (packs in parallel), the more stable the overall voltage will be, even if you have some weaker individual cells.
I think ...................................It sounds logical in my little mind But I have been wrong before.......................
Grand River Marine Modellers
Unless I missed it they don't say 1p or 2p.They only suggest that the packs total ampacity be large enough to supply sufficient voltage at anticipated loads.
HTH
Ghost
Douggie
You are a little lost here.
If you look at a discharge graph for any cells be it lipo or Sub C.
Example
4S 4500 – 25C
At 32A you would average 14.4 V
At 64A you would average 14 V
At 90A you would average 13.7 V
At 96A you would average 13.3 V
As you can see the voltage under load drops with the amp draw.
If you run a 2P setup the amp draw that each pack sees is cut in half.
Resulting in a higher voltage under load that is put to your motor.
Also only half the stress put on your cells.
If I run a 4S2P set up in my Wip and draw 100Amps each pack only has to deliver 50A
They run a lot cooler and will last a lot longer (more cycles)
If I run it on 4S1P the pack has to deliver 100A to the motor, resulting in a
- Lower motor Voltage,
- Higher battery temperature which turns into higher internal resistance
- Less Voltage under load output.
The biggest loss is in speed of the boat, even with the extra weight.
At 1850KV-- 0.7V = 1295 RPM on the motor = about 3 MPH
Even with my bad driving I will still beat you in a 1 mile race with a 3 MPH advantage
And my cells will still like me.
Yes, too much voltage drop will destroy an ESC. First the capacitors will overheat from too much voltage ripple, then they will leak the electrolite. Once that happens, they can no longer smooth out current ripple spikes. Then FETs short out and you get fireworks. Voltage ripple is more dangerous at controller's maximum continuous current rating.
Thank you Antron. What is voltage ripple in regards to capacitors, in a simplistic sense at low voltage?
Douggie
Douggie,
There is some decent information here on that topic, including a picture of before and after the application of a capacitor: http://en.wikipedia.org/wiki/Ripple_(electrical)
I wish I could take an oscilloscope to everybody and show exactly what is going on.
Ripple destroys caps, but internal impedance of the cells is what causes the droop. This is Ohms Law.
It's actually pretty slick to see the operation.
Andy
FINALLY, that is great stuff, the kind of info FE has needed for years. Makes it so much easier to decide on your initial setups without the dreaded smoke. This thread needs to be tacked in "Tips and Info for building a Fast Electric Boat !!!" since OSE sells this equipment.
ReddyWatts fleet photo
As a side note, I see lots of FE guys who appear to lack a basic grasp of the fundamental of DC electronics. There is a great book worth reading, it is called:
"There Are No Electrons" In a very easy to read format it takes some pretty dry electronic concepts and makes them clear.
Link to Book
Review
Take a look, it really is a fun way to get a grasp on the basics of DC circuitry.
Don't get me started
The chart was writen by Brian B. I beleive.
They are suggustions for race and sport setups so you will not hurt your equipment.
2P is better for your equipment.
Less heat
longer battery life
safer for your ESC's
EYC
Looks to me that Castle isn't interested in supporting the FE Racing community.
I wonder if they are very worried about the 100 or so of us out here?? 17 drivers at the NAMBA FE NATS, and I am not sure about IMPBA, did they even have an FE NATS this year?
Point is that the FE racing community is so small I doubt Castle could care less about it. In fact I wonder what percentage of their sales the marine controllers are in the first place. I'll bet a very tiny slice.
Sad fact is there just are not enough of us to really get the attention of too many vendors. I am actually amazed there are as many as we have. But let's face it, even Steven does OSE as a sideline to his real job so it's not like any vendor is getting rich off of the FE community, let alone the tiny percentage of that group that race.
Until we figure out how to grow this segment of the hobby we will continue to suffer the result of being a very small fringe group.
You are right in a way.
25C - 5000 packs
1C = 5Amps
25C = 125 Amps
If my setup pulls 125Amps and I use a 1P pack, my packs would be toast in about 50cycles
If I use a 2P pack and pull 62.5 Amps from each pack (still 125A to the motor) my packs will last over 300 cycles with out any loss in battery power.
Now if they made a 50C- 5000 pack (that would be a 250 Amp max) I could pull my
125 Amps and still get over 300 cycles.
The trick here is to only pull 1/2 of what a cells "C" rating is, to maintain full power throughout the cells life, and to extend that life.
Also there is still the higher voltage under load with a 2P setup = faster (see my post above, https://forums.offshoreelectrics.com/...2&postcount=10 )
Only valid if you double the ampacity at the same time....ie: 62.5 amps from a 2500 mah pack is still 25c
Ghost
What do you guys think would be the better setup and why. A 2s2p High kv motor or a 4s1p low kv motor if they both are achieving the same rpm. say 35,000. and the packs are the same 25c 5000mah 2s1p
