Results 1 to 2 of 2
Thread: Anyone own a Spektrum SR2000 receiver?
    4,119
    Default Anyone own a Spektrum SR2000 receiver?
    I'm looking for the length of the antenna from the outside of the case to the tip in mm. Also, I think this receiver has a single conductor antenna, and not coaxial, is that correct? Does the stock receiver have 31mm of the shield stripped off the end at the tip?
    4,119
    Found the info on another forum. 90mm from the PCB to the tip of the antenna. Non-coaxial, regular wire.
