Results 1 to 2 of 2
Thread: Any recommendations on a scale, large size cruiser boat for salt water?
    Jun 2017
    Default Any recommendations on a scale, large size cruiser boat for salt water?
    First time posting so I'm not sure if I'm in the right place.
    Any recommendations on a scale, not too fast, large size cruiser boat to mess around with in salt water harbor(no waves).
    I'm looking at something like these:
    -Kyosho Majesty 800
    -Hobbyking Princess
    -AquaCraft Rescue 17
    In 00' I had a Dumas hotshot sprint with KB outboard.
    But I sold it shortly after seeing how fast it was going (35-40mph).
    I've also watched and read information on what to do after operating in salt water.
    Shawn
    Nov 2008
    Ql
    3,169
    I've had this one for a while.
    It is a fully submerged drive unlike the Princess which is a surface drive. Much more scale like.
    I'm not sure about the other boats you mentioned. I've never seen them.
    http://www.hobbyease.com/bright-sun-...ray-p6080.html
    It is also available from Hobbyking but only in white.
    https://hobbyking.com/en_us/hobbykin...935mm-arr.html
    The Hobbyease version has too high a kv motor at 2700kv, & the 45mm prop is way too big & really unsettles the boat, & is too fast at only 1/4 throttle. The ESC will burn out.
    I don't know what the Hobbyking version has in it.
    I have replaced the motor with a 1000kv motor spinnng a 37mm prop on 2s lipo. It is still over scale speed at full throttle, but much more drivable.
    Here's a video with the original motor & the 37mm prop.
