Results 1 to 5 of 5
Thread: updtated news on 40 size motor on zelos twin 36...attention...Darin Jordan
    Sep 2016
    56
    Default updtated news on 40 size motor on zelos twin 36...attention...Darin Jordan
    I want to see if it's worth the effort or expense of upgrading the motor in the twin zelos from a 36 to 40 size motor. Could be the 4082 dynamite or other brands. Also, if change is made do you recommend upgrading the esc from 120 to 160 or 180amps?
    Thanks,
    Don Bonomi
    WA
    8,335
    I upgraded the motors to the Voracity 36 motors. No other changes. Only issue I had was that the motor mounts would shift, and rotate on their screws in a tumble, causing the drivelines to obviously not line up. Kind of annoying. If you can support the fronts of the motors, you'd be good to do so.
    Worth it? Well... only if you want to go faster with MUCH less strain on the motors and power system. :)
    Darin E. Jordan - Renton, WA
    9,402
    There is the opportunity for someone to make a rear motor support that helps prevent the motors from shifting.
    Jun 2015
    Wi
    734
    Could just use something like this if there is enough room
    http://offshoreelectrics.com/proddet...prod=ose-83005
    Oct 2013
    la
    8,740
    I put tp 4050 2050kv motors in mine. Jb welded the mounts in place. No issues yet. Goes 65mph on 4s.
