Cartwheeled the z-boat today and while it landed right side up, it was running sort of crooked afterwards. When I opened it up later it looked like a cable was not pinched down well under the set screw. The rudder was also a bit off center. So I loosened both cables powered up the servo and centered the arm.
So now I am wondering with both set screws loose, do you just let the cables fall where the might? Should I pull on them some to add tension before I tighten the screw? The instructions don't get down to that level of detail.
On the same note. The turning radius seems pretty large. I'd like to see if that can be tightened up some. I know about the dial on the side of the TX. It's on Max now so using that is not an option. Other ideas?
