Results 1 to 6 of 6
Thread: revo graphene
    Jun 2011
    ct
    826
    Default revo graphene
    took my revos down to 0% by mistake today on my 6-s fightercat daytona. 2 3s 5000ma. silver go packs 70c. very slight puff. cycled 5 or 6 times. 2 cells @.9 , 1 cell @ 1.0. do you think they will be ok?
    4,119
    One way to find out... but you might have a hard time getting your charger to recognize the pack with voltages so low.
    Jun 2011
    ct
    826
    Default revo graphenes
    my post said i cycled them 5 or 6 times. my question is: after taking them down so low, and they are very slightly puffed, will they be ok? resistance is low as they were before they were run down.
    Mar 2017
    Ny
    72
    My prophet duo sport won't charge a battery
    That went down that low. I get a -33- error
    message. Was told to try to cycle on nimh
    To bring the cells up first but that didn't work either
    The pack started to puff so I got rid of it
    4,119
    Quote Originally Posted by urbs00007 View Post
    I incorrectly assumed that cycled count was simply their total number of cycles, implying they were essentially new. If you've been able to balance them and noticed to further ill effects, I would run them. If your IR's are all low like they were before, I say run them. I would imagine they might not output like they used to.
    FWIW, I received a Turnigy Graphene 2S pack from HK that had a cell below 1V when it arrived. I got it replaced under warranty, but decided to try and revive the pack anyways. Since then, that pack behaves exactly as the other two identical packs. It balances fine, takes the same charge, and discharges at the same rate.
    Oct 2013
    la
    8,740
    Graphenes are more forgiving from what I've seen.
